Hello all I am new to the forums, I generally try to Google and fix the problem before asking on any forums, but I have been searching for quite some time on this issue, The volume for media playback is way to low in windows I have tried everything from disabling enhancements, I also have installed SRS HD audio software also with low volume.
If someone could recommend an audio booster, or anything that would boost SRS Audio output would be great or any other fix. Thanks in advance for the help.
I also after using the default driver provided by Windows 8, updated to the newest Realtek HD driver, and still no difference.
- Windows 8 Enterprise, Lubuntu 12.10
