Volume Meter
    Windows 8 64 bit
    Volume Meter
    Not sure if this belongs here, but I posted in Sound/Audio and got no responses.
    I assume this is probably something you can change is Regedit.
    When I press my FN keys that control volume, the +volume and -volume do not make the metro style volume bar show up. However, when I press mute, it shows the volume bar. When I press mute/unmute and then +volume and -volume, the bar shows up and it slides, but it quickly disappears even though I keep changing the volume.
    Here are images of the bar I am talking about just to clarify
    Volume - Imgur
    I had something very similar on my desktop. One day the volume meter worked and then for almost a week didn't show up at all. Then all of a sudden it re-appeared and has been working ever since. During this anomaly, there were some MS updates, so not sure if that had anything to do with it. All is working fine now.
    Orbiting the Moon
    Windows 10 x64
    Quote Originally Posted by jbartolozzi View Post
    Volume - Imgur
    The second time when it's not working, it also doesn't work in the taskbar/notification so it seems sound is disabled or drivers failed (to load). You can click on the sound icon in the taskbar and a troubleshooter will start to analyse the problem.
    I'd recommend a sound driver update, knowing what sound card that is.
    Quote Originally Posted by bassfisher6522 View Post
    It's possible one of the updates contained the sound driver.
    That's why is recommended to check for updates.
    When the updates don't find sound drivers then the user has to search for those manually online.
    This is kinda funny i would pay money to disable that thing. It annoys me.
    Orbiting the Moon
    Windows 10 x64
    Quote Originally Posted by tonicer View Post
    This one then:
    Anyway to disable popup's like the volume indicator overlay meter thing? When i change the audio volume with my mediakeys on my keyboard it pop's up. It annoys me greatly.
    If it's the one that appears on top left of screen, I don't know how to disable it.
Volume Meter
Mic volume too low in Sound & Audio
Hey is there any way to increase the mic volume besides the one in the controll panal thing? I maxed everything out but it's still not enough ;(...
I have a OneTouch meter and when I upgraded from Windows 7 to Windows 8 I waited a long time for a new cable, usb to serial comm, along with the drivers. I installed everything and it worked fine. Now I upgraded to Windows 8.1 and when I plug in this cable the device manager reports this device...
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Network meter for win 8.1? in Network & Sharing
Hello. Anyone know of a small, free network traffic monitor? At work, I use my iPhone as ripe for my Aspire One with win8.1, and I'm a bit in trouble late in the month since I only have 3 Gbyte data Included in the my mobilabb. So I would like a meter that measures the traffic and writes a...
Solved Volume OSD in Sound & Audio
Solved it on my own! I just ended the Task Manager task, everything seems fine, nothing has died yet :sarc:. So I've been running Windows 8 for a while now, upgraded from Windows 7. Now that Microsoft has implemented a pretty good looking volume OSD I would like to disable the default one....
I enjoyed having the CPU meter on my dash with windows 7. Is there a way to get that on my desktop or start screen? Thanks!
