HELP!..can help anyone?
  1. #11
    INDIA
    Windows 8 PRO
    I've downloaded the driver and installed it in win 7 compability mode and even plugged my HEADPHONES but still no sound..
  2. #12
    INDIA
    Windows 8 PRO
    Ive downloaded and installed driver in win 7 mode still no sound from speakers or HEADPHONE..
  3. #13
    Windows 8.1 Professional 64-bit
    I'm a little stumped, can you post a screenshot of this window? I'd like to see what it shows for you.
    It can be found in Control Panel, Hardware and Sound.
  4. #14
    INDIA
    Windows 8 PRO
    here it is
  5. #15
    It seems like everything is fine with the drivers. Your computer is showing nothing wrong. You should be getting sound. All I can think of right now is what fireberd has suggested.
    If there is still no sound on the rear GREEN speaker jack with the speakers, plug a headset into the rear GREEN speaker jack and see if you have audio
    Like fireberd pointed out, triple check that you've connected your audio device into the green input (I'm sure you already have). Try the front and back speaker jacks.
  6. #16
    INDIA
    Windows 8 PRO
    NOSOUND in front panel too.. can help?
  7. #17
    It's possible that the manufacturers haven't updated their drivers to run on Windows 8; but then they wouldn't install in the first place, I think. Honestly, I don't know how to help. I wouldn't contact GIGABYTE support and see what they say about this.
  8. #18
    INDIA
    Windows 8 PRO
    ty...bro
    but pls inform me if u can help..
    im thinking of reinstalling windows 7..
  9. #19
    Quote Originally Posted by HeX View Post
    ty...bro
    You can re-install Windows 7 on a different partition so that you can choose if you want to boot into Windows 7 or 8. Here's a guide, just scroll down a little bit.
Page 2 of 2 FirstFirst 12
