Audio Alerts Disrupt Java Audio While Live Streaming
    When I live steam video in Windows 8/Chrome, using Adobe Flash, the audio portion is silenced each time I receive an audio prompt from my system. When I say "audio prompt" I mean a beep that I believe provides some sort of notification. The video continues, but all sound disappears for a few minutes when it then reappears. I have a dual boot system. The problem only exists in Windows 8. In Windows 7 I do not have this problem. My Chrome is fully updated, which means, I believe, that my Adobe Flash is also current. I disabled (or at least attempted to disable) audio alerts in Windows 8 and in Outlook 2007 and GMail (my email clients), but the audio alerts persist as do the disruptions of Java Live streaming audio. Any ideas or suggestions for fixing this problem - either by disabling all audio prompts or solving the problem of sound disruption in Java Live Streaming.
    win8.1.1 enterprise
    hi,on your desktop ,using your mouse highlight the start icon lower left corner ,and right click on and go to control panel/sound/ click the sound tab and check off no sounds,and click for no sounds in sound scheme
    The Problem Persists
    Thank you for the response. I tried to disable sounds as you described, but I still receive audible alerts (a beeping sound) and my audio is still disrupted when playing videos with Java. Is there something I am overlooking?
    win8.1.1 enterprise
    an assumption only,if windows sounds are disable then it has to be another program making the sound ,one would think anyway ,its been years ,but i kind of remember this from the past ,and a person had same problem ,but i cant remember if it was a virus or just another program that was running all the time in the background, check your computer viruses
So here's my problem When I watch YouTube videos I get random stutters where the sound skips. The image doesn't seem to freeze though, just the sound I also get issues with the sound streaming music online, where it pauses for a second and stutters even though it's not buffering. When this...
Hello, Got a new machine, and installed it fresh windows 8.0 -> 8.1 download/upgraded. I've done what I felt were the basics. Ensured all drivers to knowledge are good, performed work on it. When I seem to be playing games in fullscreen mode, being captured to a streaming software that...
Hi there I have the Logictech Media streaming server (have a load of hardware around the house) However it CAN play locally -- but you needed SQUEEZEPLAYER on Windows (now not really available anymore). The server is still maintained both in Linux and Windows. As I usually use Linux I was...
Hi there I've found this absolutely brilliant (and plays FLAC too). 1) Download on your COMPUTER the FREE Logitech Media server - plays Music, Radio etc etc. Index of /LogitechMediaServer_v7.7.2. You don't need to own any Logitech devices to make download and use this. 2) if you want to...
