sound driver installed still no sound
    INDIA
    Windows 8 PRO
    REALTEK AC97 sound driver installed Working fine!..showing status working but no sound..after updating PC to win 8..worked well for Win 7..Need Help..
    Try re-installing/searching for a newer driver. Besides using Device Manager to search, you could go to you OEM's site to see what's available driver-wise for your machine there. Turn your sound up?
    INDIA
    Windows 8 PRO
    ANY other SOlutions?
    INDIA
    Windows 8 PRO
    Already Tried this..
    Update firmware for sound card? You really haven't given us much to go on, including, originally, knowledge of what you had already tried.
    INDIA
    Windows 8 PRO
    Quote Originally Posted by znod View Post
    i didnt knew bot OEM's SITE and its not driver problem all drivers installed well sound looks like working but no sound from speker or headphones..
    right click your sound icon...click playback devices...then select your default device...eg external speakers and set as default.
    Note: just my opinion, but I found that once 8 is installed and sound drivers are installed...8 natively seems to select the digital audio device as default.
    INDIA
    Windows 8 PRO
    Quote Originally Posted by bassfisher6522 View Post
    my speakers are already set as default device
ASUS Sound Driver? in Drivers & Hardware
Hi all, so my motherboard is an ASUS model M2N-E and I just managed to fix the problem that prevented me from successfully installing Windows 8 earlier today. Now that I'm running Windows 8, I plugged in a brand new set of Harman Kardon Soundsticks III and the sound quality is terrible. Very...
IDT sound driver in Sound & Audio
sir, i have HP PAVILION DV6 nd i m using windows 8 pro. i installed IDT audio driver (provided by HP for win 7) in win 8. it installed successfully bt its not working. it has no any effect it is just useless. can u give me any solution for this. suggest me IDT audio driver which is compatible with...
Solved Sound Blaster X-Fi Driver in Drivers & Hardware
On Friday 10/26 I upgraded to Windows 8 Pro and found I still had the SB driver problem for the X-Fi which is not supported by Creative anymore since my system is now over 4 years old. I'm not sure exactly when this original X-Fi card came out. I tried different Creative drivers as I had in the...
