Recording sound, playback sounds strange and distorted
    Gateshead
    Firstly Hi, i'm brand new. Secondly, apologies if this has already been covered.
    I recently purchased a Lenovo G580 from Curry's. My main intention of use is to write and record music on some music recording software. This software hasn't arrived yet, so I was playing around with the Sound Recorder. When playing back the recording I get a weird noise, which I can only describe as sounding like it's being played underwater. It's like a wobbly, distorted noise.
    I have tried using a third party sound recorder and have also used a different audio player and yet the problem persisits. Can anyone help me out with this?
    Much appreciated,
    R
    Strathpine, Queensland
    Windows 8 Pro 64 Bit
    Quote Originally Posted by renegade View Post
    Much appreciated,
    R
    Hi Renegade, welcome to Eight Forums!
    When you're doing so, are you using the built in microphone? (I'm presuming it's a laptop, correct me if I'm wrong). If you are, it may very well be the microphone recording quality itself, try a new one maybe? That applies for headsets, microphones on their own and external recording devices.
    Also, try in a VERY quiet room, play some music while recording (from an iPod or something) and see if the playback still has that sound overlay. If it does, then it's the microphone.
    Gateshead
    Hi and thanks for the reply.
    Yes, I'm using the in built microphone and it's a laptop yeah. Thank you I will try that out.
    I'm sure I remebmer having this problem on an old laptop years ago but can't remember the fix.
    I'll keep you updated
    R
    R
    All good mate.
    I do know that some laptop's built in microphones have a "distortion" problem when running Windows 7/8, as I experienced myself on my laptop a few weeks back, but it seemed to fix itself up. Can't remember the fix I used on my other machine with the same problem though.
    Sent from my iPod Touch
    Gateshead
    Ah right,
    I know someone mentioned 'make sure that the input isn't the output as it creates a feedback loop' not too sure what this means. But anyway I'll try that out once i'm home. Thanks for the advice.
    R
    Ah right,
    R
    Lmao, "output" on a microphone. If Microsoft made that an actual option... HAHAHA.
    But yeah, I have heard that causes problems. Going into the sound options (can't remember off the top of my head), you can check sound devices and what their device input/output is. Might be worth the look.
    On my laptop, it shows 2 devices; the speakers, and the microphone respectively.
    Orbiting the Moon
    Windows 10 x64
    First, try to update the sound drivers.
    Drivers and software - Lenovo G580(2689) Notebooks
    Also you will need to see the options in the sound; this depends what sound manufacturer (Conexant or Realtek in your case) that is and by using their software (audio settings or something like that), look for options, microphone options: sometimes damping or noise cancellation settings are available and activated (optimized for voice) and you will need to disable/change those according to what you record. Then test the micro with different settings and use what works best.
    Looking on the provided link:
    -Conexant Audio Driver
    -Realtek Audio Driver
    Choose the one you have installed.
    That's it.
Mu audio playback all of a sudden sounds like its' under water. Is there a quick, east fix??
Windows 8 When I record sound from CD, Website etc. (with Audacity or other software) it records the sound via the computers loudspeaker and from that via the computers microphone. But I want to record the sound directly from the sound card (or whatever it is). I know its possible, I have done...
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
Hi everyone, Lately my computer has been distorting sounds and been going slower than it used to. When I restart the computer, the amount of distortions/small sizzling sounds is at a minimum, but it increases as I continue to use the computer. I googled how to fix this and one of the suggestions...
Sound with Fraps: YouTube (if you turn the sound up, the problem is much more noticable) Sound with Emulator's recording software: YouTube As you can see, the audio with Fraps feels like it has a bit of distortion to it, and the problem is, while I can record this game without a problem with...
Sound garbled/distorted in Sound & Audio
For reference, I'm using the PCI version of the Sound Blaster X-Fi XtremeGamer. Lately my sound has randomly become distorted with a buzzing-like tone to it that gets progressively worse until I restart my computer. Also, at times the sound will just randomly mute until I use the Creative...
As a court reporter, I use a software (from Stenograph) which records to a .wav file as I write. I have such a severe echo during playback, which makes it impossible to even use this audiosync feature within my software. I am not very computer savvy, so I may need "dummy" type step-by-step...
