Recording sound, playback sounds strange and distorted
renegade
Gateshead
Firstly Hi, i'm brand new. Secondly, apologies if this has already been covered.
I recently purchased a Lenovo G580 from Curry's. My main intention of use is to write and record music on some music recording software. This software hasn't arrived yet, so I was playing around with the Sound Recorder. When playing back the recording I get a weird noise, which I can only describe as sounding like it's being played underwater. It's like a wobbly, distorted noise.
I have tried using a third party sound recorder and have also used a different audio player and yet the problem persisits. Can anyone help me out with this?
Much appreciated,
R
    Lenovo
Much appreciated,
R
Hi Renegade, welcome to Eight Forums!
When you're doing so, are you using the built in microphone? (I'm presuming it's a laptop, correct me if I'm wrong). If you are, it may very well be the microphone recording quality itself, try a new one maybe? That applies for headsets, microphones on their own and external recording devices.
Also, try in a VERY quiet room, play some music while recording (from an iPod or something) and see if the playback still has that sound overlay. If it does, then it's the microphone.
    Windows 8.1 64 Bit
    Intel i7 6700K
    ASRock Z170 Extreme4
    Corsair Vengeance 3200MHz 64GB
    NVIDIA RTX 2060 Super
    Xiaomi ‎XM700001 + Dell P2421
    3440x1440
    Samsung 870 Evo 1TB, Samsung 870 Evo 500GB, WD Blue EZRZ 4TB x3
    Silverstone Strider 650W Gold Plus
    Noctua NH-D15
    Coolermaster Masterkeys Pro S
    Razer Basilisk Ultimate
Hi and thanks for the reply.
Yes, I'm using the in built microphone and it's a laptop yeah. Thank you I will try that out.
I'm sure I remebmer having this problem on an old laptop years ago but can't remember the fix.
I'll keep you updated :)
R
    Lenovo
R
All good mate. :)
I do know that some laptop's built in microphones have a "distortion" problem when running Windows 7/8, as I experienced myself on my laptop a few weeks back, but it seemed to fix itself up. Can't remember the fix I used on my other machine with the same problem though.
Sent from my iPod Touch
    Windows 8.1 64 Bit
    Intel i7 6700K
    3440x1440
    Noctua NH-D15
Ah right,
I know someone mentioned 'make sure that the input isn't the output as it creates a feedback loop' not too sure what this means. But anyway I'll try that out once i'm home. Thanks for the advice.
R
    Lenovo
Ah right,
R
Lmao, "output" on a microphone. If Microsoft made that an actual option... HAHAHA.
But yeah, I have heard that causes problems. Going into the sound options (can't remember off the top of my head), you can check sound devices and what their device input/output is. Might be worth the look.
On my laptop, it shows 2 devices; the speakers, and the microphone respectively.
    Windows 8.1 64 Bit
    Intel i7 6700K
    3440x1440
    Noctua NH-D15
First, try to update the sound drivers.
Drivers and software - Lenovo G580(2689) Notebooks
Also you will need to see the options in the sound; this depends what sound manufacturer (Conexant or Realtek in your case) that is and by using their software (audio settings or something like that), look for options, microphone options: sometimes damping or noise cancellation settings are available and activated (optimized for voice) and you will need to disable/change those according to what you record. Then test the micro with different settings and use what works best.
Looking on the provided link:
-Conexant Audio Driver
-Realtek Audio Driver
Choose the one you have installed.
That's it.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
