Static on both my Xonar DG and Nvidia GTX460, need help.
    So I recently installed Windows 8 and I am getting Static out of both my GPU and my dedicated audio card, I tried reinstalling the drivers multiple times with no luck, I also tried the unified Xonar drivers with no luck. I would think it was my card or speakers but its affecting the GPU sound also and I tried multiple speakers/headphones on both, I am pretty confused about this, it seems to happen more when the hard drive is accessed(In games,heavy MKV files, etc...loading of applications while listening to music or just scrolling on a webpage at times).
    I remember this happening with my HDMI(460 card) on Windows 7 but it suddenly went away one day a couple weeks after install...so I forgot about it, my Xonar never had this issue. I use both sound sources(One for my TV, the other for my main computer) so I would love a fix for both really.
    I am kinda an Audiophile and honestly this is keeping me from enjoying anything
    Any ideas?
    As both are doing it, this suggests something other than the actual hardware audio or video cards.
    Assuming you don't have wi-fi on the desktop (that is a known source of noise), a shared IRQ, for example on the sound, would be one possibility. One thing to try with the Xonar, go to the Device Manager, RIGHT click on the entry for the Xonar and then LEFT click "uninstall". Then restart the PC and when Windows starts it will detect and reinstall it. Sometimes this puts the sound on a different shared IRQ and if that was the problem could fix that.
    I have a computer based recording studio, so I'm always on guard for sound issues.
    Do I uninstall all of the ones that say Xonar? Or just Speakers?
    The Device Manager is where you uninstall the Xonar
    Go to the Desktop and then hold the Windows key down and press the Pause/Break Key. This will bring up the System Panel. The Device Manager is listed at the upper left of this panel.
    Here is the picture of my Device Manager/Sound. I have RealTek sound, yours should show your Xonar and Video Card's sound (mine is ATI).
    Ok I seem to have a bunch of GPU ones, disable them all? Thanks for all the help so far.
    Yes, I would uninstall them all and then let Windows reinstall it on boot up. When You Uninstall, DO NOT check the box to also uninstall the drivers (on both the Xonar and NVIDIA).
    One other thing I see is a Webcam. These have been known to cause sound issues. Disconnect the webcam and see if that makes a difference.
    I uninstalled them all, it seems to have worked.
    Thank you :-D!!
    It was short lived or maybe a coincidence but its back to being static again.... :-/
    Any other ideas?
    Did you leave the webcam disconnected?
    Also, disable the HDMI audio in the Device Manager, see what that does.
    My old recording studio system was a Q6600 (with an Intel Motherboard) and I never had any problems in Vista 64 bit or Win 7 64bit with it. I had an ATI Radeon HD4850 video card. I had an NVIDIA GTS450 video card but it didn't work as well as the ATI.
    Some other thoughts. With the PC powered off, reseat (unplug then plug back in) the Xonar and see if that helps. Also, if your motherboard has an on-board audio chip, make sure its disabled in the BIOS. And, if you have on-board audio, for testing, physically remove the Xonar and enable it in the BIOS and use it to see if you get the same noise.
    I'm not a fan of the Xonar sound cards, I've seen some flakey problems on the Win 7 forum with them.
Page 1 of 2 12 LastLast
I did a clean install of Windows 8.1 recently. Now when my computer wakes up from sleep I receive a DRIVER_IRQ_NOT LESS_OR_EQUAL BSOD related to cmudaxp.sys, which I've discovered is related to my Asus Xonar Essence STX sound card. I am running the Windows 8.1 beta drivers directly from Asus's...
I have a bit of a strange problem here, my main video is run from the Gigabyte Nvidia GTX460 1GB OC, it has worked pretty much OK since I had it, after installing some later versions of the Nvidia drivers (310+) I had the odd driver crash where the screen recovers, not too much of an issue. ...
Hey, yesterday I went from windows 7 to windows 8, everytime I close a game or a program with sound, this buzzing noise comes, and it wont stop until I restart my PC. Might be worth mentioning that the drivers are beta drivers, but they have been since 2012, so the shouldnt be a problem. And yes I...
Just got my first AMD card in years (maybe around ~5 years), I installed the latest driver from AMD without issues (13.10) then I installed the driver for the ASUS Xonar DS, the driver installed fine, but the sound card is not being detected as the primary Sound Device for Windows, it appears with...
So why this problem just started, I don't know. Windows 8 64 pro with a Xonar DX sound card. Works fine on start up or restart, but wont work after waking from sleep mode. Devise management says it's working fine but ITunes or Pandora, (or anything for that matter) won't play. Checking...
Static & Dynamic IP in Network & Sharing
My bro changed our IP to dynamic and I want it static although after I enter IP , Subnet and Gateway , I press save , and nothing happens I'll give you soem screenshots so that you'll be able to help , for example tell me that this option should be like this in order for it to save. Thanks for...
Asus Xonar D2X in Sound & Audio
Greetings all, I installed the Win8 Enterprise Eval 64-bit, but quickly went back to Win7 because of sound drivers. I turned on Test Mode and disabled Driver Enforcement and tried both the Asus drivers and Brainbit drivers but couldn't get a working control panel but did get several blue...
