Volume control on screen that won't go away
    Windows 8 64 bit
    So I recently updated a Lenovo 540b all in one touch screen pc to windows eight. Everything worked perfectly. Today I played some music through the stock music app and this annoying on screen volume control popped up. Since then I have been unable to get rid of it without stopping the audio service. Also since then all of the touch functions are not working. For instance I can no longer swipe from the top to close an application, swipe from the right to switch between apps, and I can swipe to the right but am unable to click on the windows button, I have use the mouse.
    Windows 8 64 bit
    More information
    Does anyone have any ideas what the cause could be? Currently I am trying a refresh of the pc. The refresh did nothing. This volume control bar stay on top of every application, it shows up in the screen lock when the pc is first started, and does not adjust volume. If I turn it down the volume automatically goes back up to 100 percent. Windows service was no help either. I believe this volume bar is affecting touch capability as well. It opened I believe with Xbox music app, I tried removing the app, but that had no effect. The only way i can remove this volume control is to disable all audio. Any ideas or suggestions would so much appreciated. It's was my wife's Christmas present and was working so well. It is killing me that something so brand new could have such a problem, and I can not find anything like it on the Internet. Thank you so much for any help.
    Windows 8 64 bit
    Solved it myself. Thanks for ALL the help
    Windows 8 Pro
    Could you post the solution I have the exact same machine and the same problem.
    Windows 8 64 bit
    Here is what I wrote on another forum to help out someone with this problem.
    "I have had the same issues. I believe the volume bar is a conflict between hardware sound controls and windows 8 audio drivers. Previously I found the only way to disable the bar was to disable all sound. There was no program or service specific to the bar, disabling all sounds service gets rid of it, but who wants a mute computer? The best solution I have come up with so far is to update sound drivers. For me I went to the Lenovo website because I have a Lenovo 540b all in one touch screen, and I downloaded Realtek high definition audio drivers for windows 8 64 bit. After install I had sound and voila, the bar disappeared. It did come back again a few days later after testing the touch controls for sound. I reinstalled the driver and will simply stay away from any built in sound control, and control the volume through desktop controls. I have spent countless hours with this problem, and I know there is very little information available on the web. Hopefully it will be brought to Microsoft's attention soon. I hope this helps all of you. I know how frustrating this is because it also completely messed up all touch function. If I come across a better fix I will post. But for now I recommend going to your pc manufacturer's website and downloading the appropriate audio driver updates. A refresh or clean windows install will not help. I tried both. I also tried disabling all services not necessary with a selective startup through msconfig as previously mentioned. None were successful. It is definitely a hardware and windows driver incompatibility."
First up I am a not a too computer smart 70yr old. For some unknown reason the volume control icon has disappeared from my task bar (when I move my mouse hard right and it shows battery state. internet access, language, volume etc.) which I use continuously. I have been to every avenue I can think...
Im sorry upfront I don't know how to look up my specs. My volume randomly turns all the way down to zero on it own! on all devices (headest/speakers). It says all my drivers are up to date. I will reboot and the volume is restored back to 100%.Ive also checked communications tabs and the checkbox...
I recently purchased the Polk Hampden Speakers. For some reason, the manual volume control built into the speakers themselves doesn't affect the volume level. The only way I can adjust the volume is by using my computers volume control software (the little white speaker in the bottom left of...
Make Volume Control On Top in Sound & Audio
I have a couple of speakers I use with my Desktop computer. On a previous set of speakers, the power button soon wore out, so with this current set, I have them on a power strip, and use that button. This solved that problem. I now see that the volume control on my speakers is becoming...
Hi all, Just joined up.... What I want is actually the opposite of what most people are looking for. I want to install windows 8 on my kids computer but want the volume level to be set at a certain level so the sound is not to high no matter what they do. I am able to achieve this right now...
Volume Control in Sound & Audio
Hi Guys, anyone know if its possible to get an on screen volume control when you are playing music. At the moment I can only see how to start and stop music from playing. I can turn the volume up and down via my keyboard but would like to do it on screen via my mouse. If I drop to my old...
Previously I was able to pull up the on-screen media display when I press the volume button and previous/next tracks button on my keyboard but now the on-screen notification has disappeared and the volume control is not working. I am using logitech keyboard and I want to use the metro style...
