Front panel no left sound
    Windows 8 Pro
    Hello,
    I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly.
    My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone jack on the front panel works perfectly and my speakers, which are connected to the mobo's jacks, work perfectly. I've tried uninstalling and reinstalling audio drivers but that doesn't help.
    What can I do? I don't understand how the jack can give audio only to the right side of the headset... (Headset is 100% working)
    Check the HD audio plug that is connected to the motherboard to make sure its fully seated. If that is OK, the problem is either in the cable or the front panel assembly in the case. If you have an AC97 connector, use that instead of the HD Audio connector for the motherboard and see if that makes a difference. If there is no difference, the problem is most likely in the front panel assembly. There is a chance its the motherboard but 99% the front panel.
    Windows 8 Pro
    I've checked out that the cables are well connected, I'm using the HD-audio cable which is connected to the hd-audio pins. I've also tried out AC'97 but neither works...
    How can the front panel assembly be wrong? How can I check it out?
    I've had bad front panel assemblies in new cases. I had one that had two USB ports but only one worked. I had another that the connector for the cables from the motherboard was not installed correctly.
    You will have to take the front panel off to inspect it to see if there is anything physically wrong. It will take an ohmmeter and some electronics knowledge to further troubleshoot.
Hi everyone.. I'm having a problem with my sound setup. I'm using Windows 8. I have a 2.1 channel speaker, headphone and microphone. On rear, I've connected my 2.1 channel speakers and on the front jack, I connect my headphones and microphone. The headphone works fine but Windows won't detect...
Hi. I have so many problems with windows 8.1 i have seriously no idea where to begin. First one i would like to have fixed is this damn sound, happened to me first time i installed windows 8.1 aswell, and i have no idea how i fixed it. The speakers are set to Quadraphonic, i have tried all...
No sound from front panel in Sound & Audio
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
Hi, I'm so so sick to death of this. Microphone won't work at all. The plugin for the headphones works SOMETIMES. Right now it's not. It's a good system so I'm thinking it's the Creative drivers which are up to date. It's an Audigy card. Not sure what other info will be needed. ...
I have a Gigabyte GA-F2A75m-HD2 (Rev 1.0) board and this is quite an odd one. The front port worked with Ubuntu and other Linux distros but it seems to be the opposite case with Windows 8.1. I installed the latest Gigabyte version of the Realtek HD Audio Manager but it still doesn't work. What...
Hi, Iím having a problem with the front panel audio of my new Antec One case. While the headphone jack plays sound fine the problem is that it doesnít detect when headphones are plugged in and does not mute the rear speakers. Jack Sensing is not working at all and Realtek HD Audio Manger marks...
