Audio service won't start
    Windows 7 Ultimate
    I did an upgrade from Windows 7 to Windows 8, and am using the on-board sound (which is realtek), until Auzentech release new Windows 8 driver, the problem is on reboot, Windows 8 loads up and each and every time I get the Windows audio service hasn't started, so it's either use the audio trouble shooter or go into services manually to restart the service, is this a know issue with Windows 8 or could it be something else. Does anyone know how to get the audio service to start automatically, because it's rather quickly becoming a pain in the butt to have to run the trouble shooter each and every time Windows 8 reboots.
    I assume, from the Auzentech comment, that you have a separate sound card. If that is the case it needs to be removed until you do get the needed drivers. With it installed and enabled and the on-board RealTek enabled they can conflict and cause many problems.
    However, the Windows 7 drivers should work. I have an HT Omega "Striker 7.1" sound card in one of my Win 8 systems and the Vista/Windows 7 drivers work without problems. Same way, in my recording studio system, the Windows 7 drivers for my audio gear works OK in Windows 8.
    Windows 7 Ultimate
    I do have a stand alone card but it's not in the system at the moment, just using the on-board sound, but as I said each and every time that Windows 8 has to restart the audio service fails to start no matter what and I have to manually run the audio troubleshooter to start the service even though in services.msc all audio services are set to automatic, but just refuse to run. Maybe I need to do a fresh install instead of the upgrade.
    There are two drivers listed on the Gigabyte site that you should install. (1) AMD Chipset Drivers then (2) RealTek sound.
    See if this helps.
    GIGABYTE - Motherboard - Socket AM3+ - GA-970A-D3 (rev. 1.0/1.1)
My pc is running on Windows 8.1, and it was running prefectly fine till yesterday. Today when I started it, the audio icon in the taskbar had this red-cross symbol next to it, and the audio wasn't running. I clicked on the icon, and instead of the volume control menu, a troubleshooter popped up...
Hello! This is my first time asking for help; thank you for your time. I have an Asus N550JV laptop with windows 8. It has been working great the last year, but after a recent windows update, my audio completely stopped working. After running the troubleshooter, it stated the following: ...
Hello i have a windows 8 laptop and today the sound just stopped working. The windows audio service will not enable and everytime i try to enable it fails due to a duplicate in"Windows Audio Endpoint Builder. Now tricky part is i cant open control pannel as it doesnt load, i tried reinstalling...
Solved Audio Service not running in Sound & Audio
My install went OK with the exception that I have no sound, I installed on a HP Pav m1050y Intel Pentium 4 with a Creative Audigy 2Z S sound card. In Services when I attempt to start this error returns "error 1068 the dependency services or group failed to start" Any ideas out there on how to...
Hi all, I have tried the drivers from RealTek and also the drivers from MSI. (My motherboard is MSI P35 Platinum). Driver installation / removal always proceeds without any errors. But the Audio Service just can't start. In some places, the RealTek device reports status "working properly"....
