How to change channels in stereo sound ?
    windows 8 pro x64
    Is there a way to swap left and right channels ? I couldn't find a way in my titanium x-fi sound card settings and software . Thanks.
    windows 8 pro x64
    I found out a way ...
Laptop: Sager NP9150 Receiver: Sony STR-K850P Audio: Realtek HD Connection: SPD/F Optical Cabe Listening mode: AFD Auto - runs everything as 2.1 Issue: when I know I'm utilizing a 5.1 source, the receiver only auto-detects 5.1 sound from DVD movies. Sources such as Netflix streaming and...
Ok first thing is that I've already been looking for a solution through google and I did come across this: http://i.imgur.com/xmSnqUM.png I changed it to what the picture shows and my volume is still very quiet. I've also checked if my drivers were up to date and they were. The strange thing...
Greetins all, Is there a way for me to decide where what sound is played? I got it setup now that all communication is played though headset but all other sounds are sent out though the HDMI cable to my sound system. I know some games and application allow me to select under options...
Solved Audio channels reversed using USB in Drivers & Hardware
Not sure if this is a hardware or Win 8 problem. I've now run four dacs off two USB 2.0 ports and each has had the channels reversed, per the Windows 8 Sound test among others. There is no problem with the Dacs - I've checked elsewhere - and the interconnects from the Dacs have run to the proper...
First of all, to all those having problems with sound, I would suggest the following. Go to Control Panel, Programs, and uninstall the audio driver. Reboot. Then try to play sound. You might think that you would not hear any, before installing a different audio driver, or reinstalling the...
Hi. Maybe you know a way to watch BBC channels online without that frustrating proxy business? Any ideas would be helpful :) Thanks.
Whilst I plan on experiementing more, to work out what precisely is affected, I'm noticing something weird in Win8 RTM. I am using a Nvidia GTX680 over HDMI, taking 7.1 @ 16/48, to an external audio processor. If I play a .wav file through Windows Media Player, all is normal. Stereo output...
