Solved Please help no sound!
fnyny
PC Rookie
Sweden
So..well i had windows vista business 32bit and I did a system restore and the sound didn't work. then i upgraded to windows 8 and the sound still wont work...
I have done almost everything rebooting,refreshing downloading new drivers etc. But when i plug in my speakers windows says ''no speakers or headphones are connected'' and when i go on to playback devices i have 4 options all witch are the same named: Digital Audio (HDMI) and its weird because i don't even have a HDMI port on my computer nothing helps PLEASE!!!!
    Win 8 Pro
    HP DC5800 Microtower
    nvidia 240 GT
    LG
    Low
First suggestion, install the correct sound driver from the PC (or motherboard if its a home built system) vendor. Windows will install a lot of drivers but tends to install the generic HD Audio Codec rather than the correct sound driver.
Your "Speakers" (sound card) should be set as the default Playback device in the Sound Panel.
First of all ''speakers'' doesn't appear in playback devices or in Device manager.
second of all i have tried to install the driver but it does not work i have tried different drivers old ones new ones etc.
when i try to install the soundmax driver i get an error ''sound drivers lack support for computer hardware''
and when i go on ''dxdiag'' on the sound tab theres nothing only this: No soundcards found. If there is one, you should install a sound driver from the hardware manufacturer.
    Win 8 Pro
    nvidia 240 GT
    LG
    Low
Please list your system spec's. Can't really do much more than guess without it.
Time of this report: 12/20/2012, 19:32:53
Machine name: FILIPPC
Operating System: Windows 8 Pro 32-bit (6.2, Build 9200) (9200.win8_rtm.120725-1247)
Language: Swedish (Regional Setting: Swedish)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq dc5800 Microtower
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2 CPUs), ~3.0GHz
Memory: 2048MB RAM
Available OS Memory: 2032MB RAM
Page File: 1578MB used, 2500MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 32bit Unicode
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
    Win 8 Pro
    nvidia 240 GT
    LG
    Low
According to the HP site this has Integrated High Definition audio with ADI1884 codec sound device.
First thing, make sure its enabled in the BIOS. If it got disabled it would not show up and you would not be able to install the drivers.
After you verify its enabled in the BIOS, download the motherboard Chipset Drivers and the Sound Driver for Windows 7 (they should work OK for Win 8 as my RealTek Windows 7 drivers work perfectly). The reason for the Chipset drivers is that one of the prime things the chipset drivers do is identify all the devices on the motherboard and that would include the sound module. The devices must be identified before attempting to install drivers.
HP Compaq dc5800 Small Form Factor PC*-* Download drivers and software - HP Business Support Center
Fireberd thank you! it was the BIOS you're the BEST!
    Win 8 Pro
    nvidia 240 GT
    LG
    Low
Great, glad I coud help. Merry Christmas.
Good job, Fireberd!
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
Ditto...Good job, Fireberd!
One of the most forgotten items in a install or reinstall is the chip-set update and BIOS....you think it would be noted more often
Merry Christmas from sunny Florida (Tampa Bay) to Fireberd and all....abs
    MS Windows 8.1 Pro 64-bit with WMC
    Custom
    Intel Core i5 650 @ 3.20GHz X4
    H57M01
    8.00 GB Dual-Channel DDR3 @ 665MHz
    Nvidia GeForce GTX 550TI Superclocked
    2 ...1T each
    750 Corsair
    wireless
    wireless
    60Mbps tested @ 68.92Mbps/5.87Mbpsbps
Thanks, guys. Merry Christmas from Inverness, Florida. Not far from abseh1.
Jack
