HDMI Audio Device "Not Plugged In" post Windows 8 upgrade.
    Adelaide
    Hi all,
    Recently upgraded my Dell Latitude E6420 to Windows 8.
    When I attempt to use my Sony TV as a second monitor via HDMI cable, I no longer get audio. Cable is fine and worked previous to upgrade.
    Video comes up fine. In "Playback Devices" (with both "Show Disabled" and "Show Disconnected" devices checked), Digital Audio is greyed out and unable to be selected as a default device - simply says "Not plugged in".
    I've tried updating various drivers, but to no avail.
    Display adapters:
    • Intel(R) HD Graphics 3000
    • NVIDIA NVS-4200M
    Have been reading through forums etc. for the past few days, but no joy. Very frustrating.
    Any help would be much appreciated.
    Cheers.
    When you plug in an HDMI cable, the HDMI becomes the default audio playback device, rather than the "Speakers" (the PC sound card). You will have to manually change the default playback device back to your speakers in the Sound Panel.
    Adelaide
    Thanks fireberd,
    Apologies - I may not have been clear. The HDMI audio is not working at all. PC speakers work fine. The playback device isn't even recognizing the HDMI cable as plugged in, even when video is working on the Sony TV.
    HDMI should be set as default audio playback device, not "digital" Audio.
    The Dell users forum may be a better place to post since there are those there that are more familiar with your Dell.
    Laptop - Dell Community
    Windows 8 Ent
    Petea, I understand what your saying, seen this happen many times. Especially via upgrade path.
    Please note I take no responsibility for your actions, I am only providing my advice for free since it's a holiday and I have holiday blues.
    So, to get started. I am assuming you are running as a USER and not as an ADMINISTRATOR
    So these steps are for people running in USER mode.
    1) winkey + D to go to desktop mode
    2) winkey + X to open menu
    3) Select "Command Promt (Admin)"
    4) type in -> devmgmt.msc , and hit enter
    5) In the device manager under "Sound, video and game controllers" right click on each Audio device, except for any that say "Mic" and hit uninstall.
    6) scroll to the top of the device manager and look under "Audio inputs and output" and make sure that you don't see any "Digital Audio (HDMI)" ...etc... entries. If you do, right click on these and uninstall them.
    7) Winkey+I --> select the power button on the bottom right and select restart.
    See if that fixes it....
    Oh! one more thing, unplug the HDMI cable before you restart and LEAVE IT unplugged until the system is completely finished booting and finding all the audio devices. Restart one more time, log in, and then plug in your HDMI cable and see if it recognizes it.
    Quote Originally Posted by TacoTico View Post
    THANK YOU! this works for a Toshiba satillite C75D-A that had windows 8.1 on it already.
    I too have been having this issue and I have tried the above solution and it works for a while then a few weeks later I get the same issue again. The only way I have found is I have to stop everything I am in the middle of and restart just to switch audio back through the TV. My problem is I have to use my computer speakers, which I can plug my headphones into, at night not to disturb the neighbors in the next room. I then use the TV for my sound during the day. The whole time I am using the TV for my video and never have issues with the video just the audio. My question is how to solve this issue more than just a temp fix?
    United States
    Windows 8.1 Pro 64-bit
    Sounds like it could be audio card/controller issue possibly even on graphics side. HDMI is a combination of both. Also where is HDMI output coming from, Intel or discrete graphics card? System info would help.
    What do you mean HDMI output? I plug the HDMI from laptop to TV. when I go into playback devices the TV is mentioned as AMD High Definition Audio Device.
    United States
    That means your HDMI audio and video is coming from the APU graphics on your laptop. Could be a graphics driver issue or maybe the signal is dropping out between the laptop and TV thus defaulting back to laptop audio. Do you have the latest graphics drivers from HP and are you sure your HDMI cable is good including connections?
Page 1 of 2 12 LastLast
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel 9.17.10.3040 Playback Devices
Windows 8.1 Pro here The icon of "Safely Remove Hardware and Eject Media" appears even when i not have any devices plugged in. And if i click it it shows below the "Open Devices and Printers" an item with text "..." which is disabled..:mad:
I've googled the crap out of this for a week, and can't find a fix... I recently upgraded from W7 to W8, and now my HDMI audio is acting up. I have only ever used my Samsung TV as a monitor. When switching from headset to tv audio I used to click the sound icon and select "set as default" ...
Hey Guys, My VIA drivers won't install because it can't find the device. I'm trying the driver from the Biostar Website. I've tried the ones from the via website but those don't work either. I get nice clear audio but i can't configure my drivers so I can get my sub woofers working. Links...
I'll put this edit at the top, so that you won't have to read the rest if you don't want to. I fixed the problem by restoring my system to a restore point created the day I got the computer set up. I'll have to reinstall everything I've put on it in this last week, but that's better than sending...
Hi, On a fresh clean Windows 8 image, my software driver (signed) installs fine and shows up properly in the Device Manager. However once i uninstall it , subsequent reinstalls show up as 'Unknown Device' in the Device Manager. From the device details, I find that it refers to /looks for the...
