No Audio in TuneIn or iHeartRadio Apps...works elsewhere
  1. #11
    Milwaukee, WI
    Win 8 Pro x64
    FOUND THE PROBLEM!!! After 3 fresh installs...more reboots than I can count...and about 1000 'google' searches...I figured out it was the ATI Driver. I had to install the Catalyst Control Center to correct the overscan...this is what I did. Installed the entire CCC package, including the driver, from AMD. Corrected the overscan and updated the driver back to the Windows driver. Boom...worked!!!
  2. #12
    Windows 8 / Win 7 Dual Boot
    A side note, different apps on my system can play thru different devices at the same time. At least the system thinks so. Maybe I need to update my drivers too.
  3. #13
    Ok. Good for you, ck26119! It was drivers all along. Smart way to go about it too!
    I think that's always been true?
  4. #14
    My meaning is when I pull up the Volume Mixer, one device is linked to certain applications, while another device is linked to others. I guess I haven't ever had a system that used multiple playback devices, so maybe that's why it's new to me. Anyway, it would be nice to be able to change those "links" at will.
    BTW, mine was also a driver issue. Must have had an auto-update at one point overwrite the originals that were working okay.
  5. #15
    Ok. I see what you mean. It is different now. I learned something.
    Now for updates. I always configure updates to "Download and let me choose". This way I know what's going on. Downloads aren't always necessarily needed or correct.
    It's good that you figured things out! Again, I learned something.
Page 2 of 2 FirstFirst 12
I just got my new laptop with Windows 8.1 a few days ago and everything worked fine until now. When I plug in my earbuds, only the left earbud works. I've tried nearly everything I found online but to no avail. I've tried reinstalling the Realtek HD Audio drivers and system restoring to the...
Hello - I almost went over the edge last night as I was trying to get my laptop webcam and mic to work with a website that essentially gives virtual interviews. The site did not recognize my webcam and would not produce that adobe flash message that you need to agree to for the webcam to become...
Hello all. I am having a problem with a bluetooth device (Elm327 Mini, It allows you to talk and read data from your car via bluetooth). Heres the problem, It works in windows 7 fine, it works with windows 8 fine, it works in VMware with windows 7 on a windows 8.1 machine, but it will not work on...
Hi there Why do loads of GREAT apps that had 100,000's of users quite satisfied totally mess things up by "re-inventing themselves". Tunein radio (Windows version) was a GREAT app for Free Internet radio listening -- Now it's TOTALLY RUINED in its new re-incarnation on Windows -- for...
TuneIn Radio fail in Software and Apps
I'm a new window 8.1 user and I was stunned that the TuneIn radio App is so unreliable on PC. It doesn't start streaming the station most of the time and when it does it cuts off after a few minutes. I've read the reviews in the Store and problems seem to have started for most users after a...
Stream Errors On TuneIn App in Software and Apps
Is anybody else getting this when trying to connect to a station via the TuneIn app or am I the only one? I've fired off Tweet after Tweet to the staff at TuneIn but have heard NOTHING about a fix to the problem I don't have these problems when using the website or the Android app (Don't have...
Hi I want Windows Airfoil works with Music Windows App. Airfoil can you find here Rogue Amoeba | Airfoil for Windows: Wireless Audio Around Your House Windows Airfoil want a exe file in Music App to stream music to my Stereo, but I can't find the music application files. How will I do that...
