Speaker and headphone together
    India
    Microsoft Windows 8 Pro 64-bit
    Hi...in my WinXP, i was able to use both headphones and speakers together, but here in Windows 8 I find the option to only use one of them at at time. Is there a setting which can play automatically with headphone/speaker whichever is plugged in or do I need to change the default everytime I plug in a device? Thanks
    With a Dell you are, in most cases, limited to the available Dell sound drivers. Non-Dell sound drivers in most cases either do not work or do now work correctly. For example the generic Windows/Microsoft installed HD Audio Codec sound driver is just a basic function driver and does not have any extra options such as speaker configuration.
    Download the available Dell Vista/Win7 driver (it will work for Win8) four your specific model and then check to see if you have the speaker option. This assumes there is a Dell driver for your model. You failed to include your Dell model number so I can't check or link you directly to the driver. Dell drivers are at www.support.dell.com
    Windows 8 / Win 7 Dual Boot
    I'm finding that as I plug in headphones, sometimes it will switch audio to the headphones, sometimes it will not. If I go into audio properties and change the default device, it seems to fix it. But it should always recognize the change. Is that your situation as well?
    India
    Hi "firebred"..thank you for your suggestions, but i have an assembled system with just the screen being dell's. This system with all the same hardware used to work well with XP and used to play sound whether headphones or speakers are plugged in automatically without any need to change the default device.
    India
    Quote Originally Posted by thirdstring View Post
    Hi "thirdstring"..yes that is the problem, it does fix it when the default device is changed, but shouldnt that happen automatically? the same system used to do that automatically when it was running winXP.
    vvs, yes, I agree it should happen automatically. Actually, my system has gotten worse switching sounds from the built in laptop speakers to the headphones when they get plugged in. I'm still working on it, though someone updated drivers and seemed to work for them.
    Okay, I just updated my drivers for the "High Definition Audio" and it now is back to recognizing when I change devices (i.e. unplug headphones). Must have lost the drivers for awhile or something. Adding bluetooth headphones makes it a little more fun, but works reasonably well so far.
    India
    My "High Definition Audio" says it is up to date..but problem not solved..!
    My HD Audio changed to Realtek High Def Audio after it updated. Looks like yours is a custom built system. Assuming it's onboard audio, you might want to go to intel's website and see if they have any different drivers - even beta drivers may be good. Beyond that, I don't have too many thoughts. You might check the date on your drivers. (Mine is 8/21/2012) What I read is that the Windows audio system is significantly different in 8, so if the drivers were written before Win8 was RTM, I can see how it could be an issue.
Help please ! Monitor with built-in speakers is connected over an HDMI cable and so the speakers cannot be actually disconnected. Strangely, the sound feature comes or goes by either a reawakening or a reboot. Speaker icon has a red X indication when it has failed and none of the Windows sounds...
Windows 8 Headphone Jack in Sound & Audio
This seems to be a pretty common problem. I'm working on my friends computer, because his headphone jack isn't working. He has an Acer Aspire M, with a third-gen i5, 6GB DDR3, Windows 8 64bit, and a Realtek card. He had been using headphones in the side jack, and they were working fine, but...
Hi All, * I want to Make the audio Play in Headphone as well as laptop speaker at the same time. How to achieve this? * Is it Possible to play one application (example: VLC Player) with laptop loudspeaker and another application (Example: Windows Media Player) via Headphone at the same time ?...
Mic through headphone in Sound & Audio
Hi. I am having a VERY frustrating issue. I bought a Turtle Beach Earforce PX-21. (link to headset here). I use the headset for chat using teamspeak 3 while playing games. (link to teamspeak here). My motherboard is a ASUS SABERTOOTH 990FX R2.0 (link to motherboard here). The problem is pretty...
Speaker Problem in Sound & Audio
While playing a video or games or any app that has sound... the sound suddenly dissappears if it is too loud. At first I thought it might be the driver... so i replaced HD Audio with Conexant... but the problem still persists, which lead me to believe that it coild be probably the speaker's...
Solved no sound in headphone in General Support
I am using window 8 (64 bits) Speakers are working fine but there is no sound in headphone
