Best Beats Audio settings for Classical Music?
    I was wondering what the best Beats Audio for classical Music is.
    My current settings are
    Beats:80
    Treble:45
    Center: 80
    Space:80
    Focus:80
    65Hz:3
    125Hz:5
    250Hz:3
    250Hz:-2
    500Hz:-2
    1kHz:-2
    3kHz:-1
    6kHz:-4
    9kHz:-4
    12kHz:-4
    The Contemplator
    (1963-2013)
    Doncaster, UK
    Windows 8.1 Pro RTM x64
    Hi Slayerming2 and welcome to W8 Forums
    There are no best/worst/right/wrong settings for this. Music is a subjective experience, and one person's equalizer settings for their perception of the music (or whatever audio they have playing) is not necessarily the same as anyone elses. Simply adjust the settings so that it sounds right to YOU.
Hey all, I've been using a Windows 8.1 HP Envy laptop for quite some time with no problems. It used to have very strong headphone output, and I could hear it just fine even at 2-3% volume. However, a few days ago I made the mistake of going into the preinstalled Beats Audio manager and...
tried to play any music in itunes and no audio, music bar line never leaves the far left end. tried to watch video and no audio, video itself is fine but the sound disappeared no clue how or why. tried to raise the volume meter for the audio of windows itself and the audio is ok. and also my...
Hi there :) i have a small or bigger problem :) i have added my music folder to the music library. That worked! And all files there are indexed. The i start xbox music app. the app sync the library which need some time. after syncing it shows me that 7389 files are in library, BUT i have 7394...
HP ENVY 20-d094 TouchSmart Desktop How can I use 'external speakers' (using the external speaker jack on the back of my touchscreen) ... AND NOT have it over-ride the BEATS audio.? Once plugged in , the external speaker are heard BUT the BEATS AUDIO is muted. ! (OFF) Is there a way to...
MY LAPTOP HP 6121TX I 7 SECOND GENERATION,BUT AFTER INSTALLATION WINDOWS 8 FUNCTIONS WELL,BUT BEATS AUDIO A SPECIAL AUDIO EFFECT OF THIS VERSION OF HP IS TOTALLY LOST...PLEASE HELP:cry: :D:D:D PRESS FUNCTION KEY+B..beats icon will appear in system tray... Right click the icon options comes up...
