How to record both Stereo Mix and Microphone
    Windows 8 64bit
    As the topic above,
    I need help
    I using Headphone(include microphone)
    I had the latest Realtek Driver.
    My Laptop information :
    Windows 8 64bit
    Click image for larger version Click image for larger version Click image for larger version Click image for larger version Click image for larger version
    How do i setting to record the both StereoMix and Microphone??
    Anyone help me please..
    If you have stereo mix, any input should be heard on the PC's speakers and also any input should be available for recording.
    For example if you want to record your voice with a music file, you should be able to do both at the same time. Computer mic's are only for spoken voice and not singing. I you want to sing you would need a better quality USB mic or if you use a standard P.A. mic it will need a preamp as the mic level is too low for PC sound card. You won't be able to split the voice on to one track and the music to another with the PC's sound device.
    If you want to record voice on one track and music (or whatever) on another track you will need a recording interface device, such as a USB connected two channel unit. e.g. a Focusrite Scarlet 2i2, or some other similar device.
    As a side note, the "CD audio" standard (and wav file standard) is 16 bit 44.1Khz, not the 24 bit 48Khz you show. If you have a 24 bit/48Khz recorded file, it would have to be converted to 16 bit/44.1Khz if you wanted to burn an Audio CD. I have a recording studio using Sonar X2 software.
    Windows 8 64bit
    last time im using windows XP with my currently headphone without any problem
    so now what i need to do is buy a new USB Headphone(with micriphone)..?
    i usually use these function in social website, skype, recording tutorial ..etc
    Windows 8 64bit
    hello?
    no one gonna help me?
    1)Control Panel -> Sound
    2)Set playback device as your liking.
    3)Set recording device to Stereo Mix only. ( Set as Default Device )
    4)Enable your desired/operating microphone array at the same window segment also.
    5)Go to Properties of that microphone , and find "Listen to Device" , check it.
    6)If you check around more , sampling recording in same bit as your output , and 2 channels also may solve that microphone sound coming only from the left channel.
    This is tested on this machine I'm typing. On Audacity or alike , just use the Stereo Mix. You can cover songs now , albeit it will be drunkish because you are also listening to your voice at the same time. I don't know though if Win 8 or your sound support
    has "listening" property. Mine is Win 7 original and internet download , and my sound is IDT High Definition Audio CODEC ... and NVIDIA HD Audio as it writes in Device Manager , no else.
    Windows 8 64bit
    Thanks it work in step 5
    by the way my voice was test in recording, very small
    anyway, thanks
Solved stereo mix problems in Sound & Audio
I have been trying, on and off for nearly a year now and pretty intensely in the last week, to get the stereo mix problem sorted and still nothing. My system comprises; W8/64bit pro with media centre, asus crosshair v formula mobo, amd 6 core processor, 8gb ram, Creative Audigy SE soundcard. I...
I Want Record Sound On My PC But I Cant Use Stereo Mix. Please Help ?
HDMI 2 stereo only in Sound & Audio
i need help this is my problem https://www.eightforums.com/sound-audio/6655-digital-audio-hdmi-only-has-2-channel-option-2.html my posts are the last 2 plz help
I replace my old sound card, which had a Stereo Mix channel and level control on its mixer, with a Sound Blaster Audigy FX card. The new mixer has only two channels of recording: Mic and Line In. Both work. I've updated the drivers, but can't find one that adds Stereo Mix. I then installed...
Hello all! I have been searching now for hours and i guess this fourm is my last and i really hope someone could help me! Imma start of that i just format my whole C: which means i have nothing left and it was kinda nice. All new and so on so now we came so far that i downloaded Skype and im...
Can't Record Stereo Mix in Sound & Audio
I can't record stereo mix (things that I hear playing). I have an Asus N76VZ laptop with Realtek audio chip. Installed is the Asus N76 Realtek driver (6.0.1.6710). The thing is; this laptop has a specific sound system called Bang & Olufsen ICE Power. It has an external SonicMaster subwoofer which...
Title: My stereo mix doesn't work well My PC: SP 2000-2b49Ca, window8 Audio: Realtek driver: 6.0.1.6837 (installed sept 21 2013) Panel settings: External Mic: ready, level 75+20dB, 3,5mm connector Microphone: ready, level 75+20dB, ATAPI internal connector Stereo mix: default, level 75, no...
