Via HD Audio Deck
  1. #11
    Just curious, but what exactly does VIA Audio Deck bring to the table?
  2. #12
    VIA Audio Deck
    When I installed Windows 8, got dialog box saying I needed to update my audio (ASUS Rampage gene 111 mobo). Now I don't get the dialog, and no change in audio! The driver is 10,xxx (I renamed it to VIA Audio).
  3. #13
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    The VIA HD Audio Deck is the configuration utility. It lets you set number of speakers, change jack functions, setup an equalizer,etc.
    Windows 8 didn't have driver for my onboard VIA sound. ASUS only had Windows 7 drivers, they worked in compatibility mode though. VIA had actual Windows 8 drivers so that's what I used.
  4. #14
    Windows 7 has built-in drivers for codecs that follow the Intel HD Audio standard, including the Realtek and VIA ones on my motherboards. Surely Windows 8 continues to support this Intel standard?
  5. #15
    The onus is on the manufacturers to supply drivers to Microsoft for any new OS. At the time I installed Windows 8, VIA didn't have any Windows 8 Drivers available for download, and Windows 8 didn't install any default drivers. I had no sound at all. My motherboard uses a Nvidia/nForce chipset and AMD processor. There is nothing Intel on it.
  6. #16
    VIA Audio Deck
    My HP Laptop has an AMD processor. No audio problems. The most trouble I have had is with the Logitech mice (desktop and Laptop).
    I worry what will the problems be with Windows 9...if and when it appears.
  7. #17
    My other PC also has an ASUS motherboard, same chip-set as this one but has RealTek audio instead of VIA. Sound works fine with Windows 8's default drivers. M4N68 in this PC and an M2N68 in my other. I use Logitech keyboards mice and trackballs on all my PC's. No problems what so ever with any of them. The Logitech Setpoint software is another matter though.
  8. #18
    Well, that's interesting. I would hope for motherboards using Intel chipsets at least, Windows 8 is like Windows 7 and doesn't require a third party driver for audio, nor will it particularly benefit from one, and I would avoid installing one unless I needed something specific that only it can provide. (I had a bad experience with a VIA driver about 3 years ago, and 3rd party drivers bring nothing to the table for me as I just run optical to my AVR.)
  9. #19
    Um, I'm not trying to stir anything up, but if the audio chip-set is Realtek or VIA what does that have to do with the motherboard being Intel or AMD. They are both going to use the same driver? If there is no driver there is no driver? VIA have one out now so at some point you may get it over windows update and not have to go to VIA and hunt it up.
  10. #20
    I hope you are right. Being Christmas there maybe some goodwill from the software providers. We can just have faith! I am not sure what chip in the Rampage mother board needs the VIA driver, but so far so good.
Page 2 of 2 FirstFirst 12
Via HD Audio Deck
Hi guy! Today, I've install win 8 (Pro) on my PC and seem like something went wrong with my Audio driver. When i run Via HD Audio Deck to active sound to speaker jack ( If i dont, i just hear the sound from headphone jack) but it say " Via HD Deck do not support this OS version. Please update your...
Via HD Audio deck in Drivers & Hardware
Okay, once again problems... So, I have this old M4A77 motherboard with Realtek's audio "card". I've installed the drivers (I had to use Windows 7 compatibility mode) and the installation went fine, the computer was restarted Alle klar. The driver comes with program called VIA HD Audio deck,...
is there any fix for via hd deck audio crackling sound in windows 8 consumer preview my specs processor i7 2600k motherboad asrock H61M-VS graphics nvidia gt520
