Annoying problem with sound crackling and skipping
    windows 8 pro
    Hi all,
    I have read quite many posts so far regarding this issue in Windows 8. It Looks like they have overlooked the Sound skipping problem during playback on different programs and codecs. Whenever one uses Media Player, Spotify or any other audio programs the Sound skipps and crackles. It comes to the point when this is unlistenable any more. My System is definitely strong enough for handling Windows 8 Pro. I've been trying to use different methods like compatibilty installations , playback modifications , drivers etc. but nothing helps. When the system goes in high latency then the sound skipps. Do we need to wait for 64bit proper drivers for Windows 8 update or is there any other solution ? Thanks.
    London
    Windows 8.1 pro media centre 64bit
    You say that you have installed the the latest drivers yes?
    Where did you obtain these drivers did you go straight to you manufactures website normally under support?
    Or where these just pre installed by Windows.
    Also it might be worth installing the latests Chip-set driver for your system.
    To my knowledge Sony has a programme that you can download from there support page that will install all the latest update for you.
    win 8
    Hey , I have exactly the same problem ,
    with Realtek alc887 ,
    I tried everything , but with no success ...
    if you find solution pleaseeeeee helpppp
    windows 8 pro
    Quote Originally Posted by Trevers1987 View Post
    Yes, I tried almost everything. Intel 945 chipset drivers, Sigmatel 64bit for Windows 7 etc. does not working. I think they need to put the update on Windows update or release 64bit sound drivers asap ?
    London
    Quote Originally Posted by windav View Post
    Right as a far as I know Sigmatel is now called IDT, so you will be waiting a very long time for them to release any update!!!
    Your best bet is to go on over to the IDT Audio, website and obtain a copy of there latest 64bit drivers and see if they will install on your machine.
    windows 8 pro
    I think I have finally found a solution for Windows Pro 8 64bit which in fact didn't need any solution probably hence the problems....( it works al least in 90 % let's say so... ). Ok now to the point. First of all ,after you do a clean install of Windows 8 64bit do not refer to any proprietary programs from previous version of any Windows. What I mean is this:
    1. Install a clean Windows
    2. Do not install anything what is regarding the computer function keys. I mean no additional software for FN keys ,brightness , volume, wireless switches etc. leave those !
    3. Do not install any new drivers for Windows 8 if the system had already found and installed their own from the disc. Anyway, most of these new Windows drivers like sound, controllers etc. are not ready yet for it.
    4. You will not need them because Windows 8 has it's own inbuilt functions for volume, brightness etc. so don't install any from the previous systems or the ones designed for laptops.
    5. Do not install any Antivirus for now as Windows 8 has its own inbuilt Antivirus program ! Let it run.
    6. In Device Manager please leave those devices with no drivers ! Do not force them to be updated online , now in most cases they will not be updated for Windows 8. The most important will be installed from the disc.
    7. If you must install any programs that were working fine in the previous versions do this only in compatibility mode.
    It'll be working fine. It's a very nice and fast system. Very friendly and it can only get better , it's just too young for the drivers so now use it scarcely. There shouldn't be any high latency issues or sound skipping etc.
    Try this out..thank guys for all the answers.
    London
    4. You will not need them because Windows 8 has it's own inbuilt functions for volume, brightness etc. so don't install any from the previous systems of the ones designed for laptops.
    Glade you finally found the solution you had me searching the Microsoft Update Catalogue for the latest drivers lol.
    Fresh install was on the tip of my tongue just don't like jumping straight to that option and let Microsoft do it's thing.
    Yes no need for antivirus programme unless needed for specifics. Microsoft basic security is a wonderful little programme now they have combined defender with essentials.
    windows 8 pro
    Thanks a lot, no need for searching now , anyway I was doing the same for days...!
    windows 8 pro
    Hi all. Coming back to this again. Please don't rely on the solution above. I wrote it works in 90% and that's true it doesn't work in 100%. The problem exists in all Windows 8 versions both 32 and 64 bit and it is a high latency issue. It looks like Windows 8 has been stripped of the most professional approach that Windows 7 or Vista have. So for now it is not recommended for users who want to get the most of it for music productions , media etc. Take a look in here. There needs to be a new service pack in order to sort it out. For now, there seems to be no solution unfortunately...
    Windows 8's greatest weakness: DPC latency - AnandTech Forums
    Windows 8 Pro
    Search the web and you'll find at least as many complaints about high DPC latency in Windows 7...
Page 1 of 4 123 ... LastLast
Sound crackling/popping in Sound & Audio
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
just bought a new computer with windows 8. ever since its a non stop sound of the usb being disconnected and connected. anyone have this problem? im about to throw my computer against the wall :mad:
Annoying sound pannel popup in Sound & Audio
Hi, anyone having this problem ? Every time I adjust my sound, the black sound pannel show up, but keeps showing up for like 1-2 minutes and it is pretty annoying. :( Is there a solution please ?
Hello all, My sound had recently become stuttery, crackling, and sort of metallic sounding, maybe 'tinny' is the word. This is an issue both through HDMI and headphones. I've tried reinstalling and updating my drivers, I've cleaned a fairly nasty bit of dust from between the heatsink and fan,...
so i have the sound problem here was using an-old 500GB HDD for OS and things got really out of control sound and even the mouse lagged so i poped out an-even older 80GB HDD :P and installed what i had on hand a windows 7 32bit and the PC ran like a chaaaaarm for like a week then i broke the piggy...
Sound Popping/Crackling in Sound & Audio
All right, so my sound is popping at loud frequencies. For example, if I click on my volume adjuster to hear the different sample levels, little pops and crackles can be heard. I was starting to notice some crackling when I got the Logitech g35. Thinking the g35 was faulty, I got a refund and a got...
is there any fix for via hd deck audio crackling sound in windows 8 consumer preview my specs processor i7 2600k motherboad asrock H61M-VS graphics nvidia gt520
