Annoying problem with sound crackling and skipping
  1. #21
    Boston
    Windows 8.1 Pro x64
    No problem. You should try running latencymon while listening to music or doing something that messes with the sound so you can check if something its causing high latency spikes when it pops/stutters. Its a really nice tool, far more detailed than DPC ever was, and will tell you exactly what is causing spikes. It could very well be a bad driver you can easily remedy
  2. #22
    windows 8 pro
    Quote Originally Posted by zahl View Post
    Thanks, I'll check this out.
  3. #23
    windows 8 pro
    Ok...now the interesting thing. I downloaded the Latencymon. True it showed that my NDIS Driver ( network ) has the highest latency time. So I tried to update it. Now it shows NDIS driver's latency fine but still get a crackling and stuttering sound...here's the screen pic: Click image for larger version
  4. #24
    Windows 8 Pro 64bit
    Also having High Latency issues am 100% sure this is a Microsoft Issue and they need to update windows.
    Am getting same two drivers has you plus c-media and USBport 2.0
  5. #25
    Boston
    Windows 8.1 Pro x64
    You're definitely suffering from some extreme latency and I'm sure it has something to do with your issues. Does the current kernel latency stay at that level at all times? I've read that windows 8 has made some changes in the way the os timer works so maybe drivers need to catch up. What does the driver tab look like? There you can see exactly what driver is causing the issue.
    For reference this is what mine looks like;
  6. #26
    Windows 8 Pro 64bit
    These my screenshots
    Attached Thumbnails Attached Thumbnails Screenshot (1).png   Screenshot (2).png
  7. #27
    windows 8 pro
    Ok. It looks like this is the culprit. NDIS.SYS. This driver or file takes almost 60% of the processor power causing huge spikes. How this can be fixed ? NDIS is located in system32, can it be modified or shouldn't be touched at all...?
  8. #28
    Boston
    Windows 8.1 Pro x64
    The thing is that it could be almost anything causing that ndis latency. Any app or device accessing the web could be causing it. The thing I would try first is to disable all power saving features. A few include;
    Setting the pc to high performance mode in power profiles
    Disabling "allow the pc to turn off device" in device properties for nic, audio and usb
    Disabling "green power" and all wake options in nic device properties and also manually setting speed instead of using auto
    Disabling C-states and power savings in bios and if needed core parking in windows
    Also to minimize audio pops and weird sounds mute all non used inputs and outputs in sound properties. This makes a huge difference in cleaning up audio
  9. #29
    windows 8 pro
    Thanks. I've tried every step you suggested for me to do. Nothing helps so I think although my comp supports 64bit architecture it's simply not up to the par with 64bit systems.I think the chipset causes spikes etc. So maybe we should leave the topic and I should buy a new comp that will suport better 7 and 8.
  10. #30
    Boston
    Windows 8.1 Pro x64
    Sorry to bump this again but i noticed something I should share. With the latest network driver at realtek.com I notice 1-2ms ndis spikes every few seconds on both windows 7 and 8. With the latest driver from windows update there are no spikes at all. Maybe you guys can try that out as well
Page 3 of 4 FirstFirst 1234 LastLast
Sound crackling/popping in Sound & Audio
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
just bought a new computer with windows 8. ever since its a non stop sound of the usb being disconnected and connected. anyone have this problem? im about to throw my computer against the wall :mad:
Annoying sound pannel popup in Sound & Audio
Hi, anyone having this problem ? Every time I adjust my sound, the black sound pannel show up, but keeps showing up for like 1-2 minutes and it is pretty annoying. :( Is there a solution please ?
Hello all, My sound had recently become stuttery, crackling, and sort of metallic sounding, maybe 'tinny' is the word. This is an issue both through HDMI and headphones. I've tried reinstalling and updating my drivers, I've cleaned a fairly nasty bit of dust from between the heatsink and fan,...
so i have the sound problem here was using an-old 500GB HDD for OS and things got really out of control sound and even the mouse lagged so i poped out an-even older 80GB HDD :P and installed what i had on hand a windows 7 32bit and the PC ran like a chaaaaarm for like a week then i broke the piggy...
Sound Popping/Crackling in Sound & Audio
All right, so my sound is popping at loud frequencies. For example, if I click on my volume adjuster to hear the different sample levels, little pops and crackles can be heard. I was starting to notice some crackling when I got the Logitech g35. Thinking the g35 was faulty, I got a refund and a got...
is there any fix for via hd deck audio crackling sound in windows 8 consumer preview my specs processor i7 2600k motherboad asrock H61M-VS graphics nvidia gt520
