Annoying problem with sound crackling and skipping
  1. #11
    windows 8 pro
    Quote Originally Posted by NaySayer View Post
    Search the web and you'll find at least as many complaints about high DPC latency in Windows 7...
    Not really...check this out...
    Microsoft's Windows 8 Poses Audio Problems - TheStreet
  2. #12
    Windows 8 Pro
    That's describing a specific issue with USB audio, which has nothing to do with DPC latency.
  3. #13
    windows 8 pro
    So this one doesn't mention USB audio...
    Surface users report Touch Cover splits and audio issues | The Verge
  4. #14
    Windows 8 Pro
    And that one's talking about the Surface tablet, which is Windows RT (not 8) running on a specific hardware platform.
    Google "Windows 7 DPC latency" and you'll get about 60K hits. Random pops and crackling have been a persistent issue since Windows 3.1...
  5. #15
    windows 8 pro
    P.S. I've been using Windows Vista Business for about 6 years I think...I never experienced popping or crackling sound issue in it also in windows 7 and there have been so many complaints about Vista, I always regarded both Vista and 7 as really stable and excellent systems. Though 7 and 8 have both much better design and interface than Vista.
  6. #16
    Windows 8 Pro
    Whether or not you experience sound issues depends on the sound card/audio chipset, the hardware configuration, what processes are running in the background, whether you're on battery or AC power, and 50 other variables besides the OS. Some do, some don't.
  7. #17
    Boston
    Windows 8.1 Pro x64
    This is also worth trying if the option is available in your bios. Look for HPET (usually in power management section) and toggle it off or on depending on its current setting. Also, if available, set it to 32 or 64 bit to match the windows version you're running
  8. #18
    windows 8 pro
    Quote Originally Posted by zahl View Post
    Hi , the option in CMD didn't help...here is the explanation. All stuttering is the Windows' programming skeleton issue. It needs to be fixed through the Windows Update I guess:
    View topic - Windows 8 Beta - Audio pops & clicks - Windows, Apple, Application, Abandonware and Game Beta Downloads/Repository - BetaArchive
  9. #19
    Boston
    Windows 8.1 Pro x64
    I don't understand, are you saying windows 8 has higher latency than windows 7? If so that is not the case and if you are using DPC to check it i suggest switching LatencyMon which is compatible with win8 (DPC will give inaccurate readings in 8 that are much higher than they actually are). From my testing I have noticed that HPET enabled in the bios of my board produces vastly lower latency than disabled but I also think you might have to install windows with it enabled in bios for it to properly work.
    On my system, with HPET enabled in bios latencymon shows 5-10 latency with periodic spikes to 800, just like it did in 7. With HPET disabled i get a solid 800 latency with spikes to 1100. I also use both x-fi and onboard realtek with out any issues at all
  10. #20
    windows 8 pro
    Thanks for suggestion. I don't have HPET option in my BIOS unfortunately so I tried to disable it in CMD. It didn't help. There's often a buzzing , stuttering sound popping out. All drivers have been updated and all devices. So I guess this has something to do with IDE ATAPI / DMA controllers.
Page 2 of 4 FirstFirst 1234 LastLast
Sound crackling/popping in Sound & Audio
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
just bought a new computer with windows 8. ever since its a non stop sound of the usb being disconnected and connected. anyone have this problem? im about to throw my computer against the wall :mad:
Annoying sound pannel popup in Sound & Audio
Hi, anyone having this problem ? Every time I adjust my sound, the black sound pannel show up, but keeps showing up for like 1-2 minutes and it is pretty annoying. :( Is there a solution please ?
Hello all, My sound had recently become stuttery, crackling, and sort of metallic sounding, maybe 'tinny' is the word. This is an issue both through HDMI and headphones. I've tried reinstalling and updating my drivers, I've cleaned a fairly nasty bit of dust from between the heatsink and fan,...
so i have the sound problem here was using an-old 500GB HDD for OS and things got really out of control sound and even the mouse lagged so i poped out an-even older 80GB HDD :P and installed what i had on hand a windows 7 32bit and the PC ran like a chaaaaarm for like a week then i broke the piggy...
Sound Popping/Crackling in Sound & Audio
All right, so my sound is popping at loud frequencies. For example, if I click on my volume adjuster to hear the different sample levels, little pops and crackles can be heard. I was starting to notice some crackling when I got the Logitech g35. Thinking the g35 was faulty, I got a refund and a got...
is there any fix for via hd deck audio crackling sound in windows 8 consumer preview my specs processor i7 2600k motherboad asrock H61M-VS graphics nvidia gt520
