Volume mixer
    Volume mixer
    Hi all,
    after so long I've been using Windows 8, I noticed this feature(?) in this OS. See attachment.
    My question is: Why is every application's volume is half of the device volume? I tried moving the bars of the app's volume to match the device volume, but it will go back to the "half"-state again. Any idea?
    Is there any way to solve this?
    You can move the slider for System sounds, Friends and Chrome up to the level of Speakers.
    Quote Originally Posted by brummyfan View Post
    will the settings be permanent? Like for example if I close and open the chrome, does it stick?
    I ask this because I find it weird that the app's volume suddenly dropped half and I'm not so sure when will it happen again.
    It stays the same for me, hope it behaves the same for you as well.
Volume mixer
I am trying to install pinnacle studio 16 ultimate in windows 8. They say it is compatible however I am not getting any sound in the programme. The helpline says I need to turn on sound for this programme in something called volume mixer or audio mixer. Where and how do I find this in Windows 8. I...
Volume Mixer Problem in Sound & Audio
Hello guys, So i got a problem on the Volumer Mixer. All started yesterday after i decide to install my new speaker... now is giving a headache to fix to the way that was before. Basically before i could control all the computer volume but now when i go to volume mixer there is a lot of stuff...
I have an audio source connected to Line In and I use the volume mixer to un-mute the input when I want to listen to the audio from that source. I recently started having a problem where after re-booting Line In does not show up in my volume mixer and I do not hear audio from the Line In Source...
Volume Mixer Frustration in Sound & Audio
I have a Qosmio X870-BT3G23 laptop with Windows 8.1 installed. When playing a game, I noticed sound volume got quiet. When I alt-tabbed out of game, I noticed volume mixer sliders were not all set the same. I moved them all up to match main Speaker level, but it is frustrating to keep setting them...
I have an ongoing annoyance, which I've had through all Windows versions from XP or maybe Vista onwards, in that although I can individually set the volume level of each program that makes any sounds, all those volume settings are wiped out and reverted to the much unwanted default level every time...
volume mixer settings in Sound & Audio
ok... someone look at the screenshot of the volume mixer and tell me those squares belong....
