Sound isn't coming out
    windows vista 64
    When I tried to play a video on Youtube I couldn't hear any sound coming out. I tried some things, but without any luck. Someone please help.
    If you have any third party security software installed, uninstall it and see whether it fixes the problem.
    EDIT: You could also do a Refresh with this Tutorial:Refresh Windows 8
    You need a DVD to do the Refresh, I hope you have already burnt a DVD, if not burn the DVD and start the Refresh.
I just bought a Dell Inspiron 17 laptop with Windows 8.1. When I first plug my headphones into the audio jack it works and it's initially silent. However, after I finish playing any sound from any app through the headphones, a static sound constantly comes through them. It doesn't sound like...
I have an HP laptop running 8.1. I did update my computer or I restarted after an automatic update but no sound comes from speakers or head phone jacks. I have checked my drivers and they are working. My sound is not on mute. Any suggestions?
Hi. I have so many problems with windows 8.1 i have seriously no idea where to begin. First one i would like to have fixed is this damn sound, happened to me first time i installed windows 8.1 aswell, and i have no idea how i fixed it. The speakers are set to Quadraphonic, i have tried all...
Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
Recently i had this repair on my netbook screen which was needed to be opened... then after that when it returned and opened the system (i was still using windows 7 back then) all music played...it will play, but all i can hear is that sound that you can hear from a plane engine when taking off...
I was working on my computer editing music when suddenly all sound stopped. If I go into the sound mixer from the taskbar there is nothing listed under applications under speakers. If I plug headphones in sometimes Chrome shows up under applications, sometimes it doesn't. Right now headphones...
