Sound Blaster X-FI MB issues
    win 8 64 bit
    I recently installed Windows 8. My Creative suite is seen in the start screen, however when I try to initialize the console or anything else..nothing happens. The upgrader indicates I have the most recent version. I've been to Creatives site but cant find drivers for the X-FI MB. Anyone else have this issue?
    The Xfi MB is a software "enhancement" to the integrated sound module in your PC. Do you have the install program, to reinstall it? If you have a Dell, the My Dell Downloads should have the download for it. I had this on one of my PC's (provided by the motherboard vendor) but I didn't try to reinstall it on the PC that I upgraded to Win 8 as I never used the features.
    win 8 64 bit
    My Dell Downloads did have the software.....thanks!
    Quote Originally Posted by riley96 View Post
    Hey I am facing similar problem! But since my laptop is very old X-Fi MB is not there in available for download section! Could you please share the link or the software. Thanks
Greetings! I'm having a little problem here which I wasn't quite able to solve using the official Creative Support. First a little explanation: Before installing my new Sound Blaster ZxR I had to temporarily use the Onboard Sound of my Asus Rampage IV Black Edition because of a SLI Water...
The Creative Sound Blaster X-fi Xtreme Audio card works fine in Windows 8. The drivers for Windows 7 work without any problem and the Creative updater and control panel also work as they should in Windows 8. The drivers can be downloaded here for the X-Fi Xtreme Audio card - Creative Worldwide...
Solved Sound Blaster X-Fi Driver in Drivers & Hardware
On Friday 10/26 I upgraded to Windows 8 Pro and found I still had the SB driver problem for the X-Fi which is not supported by Creative anymore since my system is now over 4 years old. I'm not sure exactly when this original X-Fi card came out. I tried different Creative drivers as I had in the...
