Volume Control
    Volume Control
    Hi Guys,
    anyone know if its possible to get an on screen volume control when you are playing music. At the moment I can only see how to start and stop music from playing.
    I can turn the volume up and down via my keyboard but would like to do it on screen via my mouse.
    If I drop to my old windows desktop (which I'm desperately trying not to do) I can control it with the speaker icon in my taskbar but I can't for the life of me work out how to adjust volume on screen.
    Cheers
    Hi,
    try with Windows key + I
    Cheers
    Use your volume control from the keyboard, and when the volume screen pops up, use your mouse to adjust the volume.
    Windows 8 Pro
    Stroll to the top right and activate the Win 8 menu. Volume control is under "Setting"
Volume Control
First up I am a not a too computer smart 70yr old. For some unknown reason the volume control icon has disappeared from my task bar (when I move my mouse hard right and it shows battery state. internet access, language, volume etc.) which I use continuously. I have been to every avenue I can think...
Im sorry upfront I don't know how to look up my specs. My volume randomly turns all the way down to zero on it own! on all devices (headest/speakers). It says all my drivers are up to date. I will reboot and the volume is restored back to 100%.Ive also checked communications tabs and the checkbox...
I recently purchased the Polk Hampden Speakers. For some reason, the manual volume control built into the speakers themselves doesn't affect the volume level. The only way I can adjust the volume is by using my computers volume control software (the little white speaker in the bottom left of...
Make Volume Control On Top in Sound & Audio
I have a couple of speakers I use with my Desktop computer. On a previous set of speakers, the power button soon wore out, so with this current set, I have them on a power strip, and use that button. This solved that problem. I now see that the volume control on my speakers is becoming...
Hi all, Just joined up.... What I want is actually the opposite of what most people are looking for. I want to install windows 8 on my kids computer but want the volume level to be set at a certain level so the sound is not to high no matter what they do. I am able to achieve this right now...
So I recently updated a Lenovo 540b all in one touch screen pc to windows eight. Everything worked perfectly. Today I played some music through the stock music app and this annoying on screen volume control popped up. Since then I have been unable to get rid of it without stopping the audio...
Previously I was able to pull up the on-screen media display when I press the volume button and previous/next tracks button on my keyboard but now the on-screen notification has disappeared and the volume control is not working. I am using logitech keyboard and I want to use the metro style...
