External speaker fail
    Win 8
    The internal speaker works fine, but when I plug in the external speaker, (speaker plug + USB) it seems to mute the whole system. Anyone else with the same issue?
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    Laptop? Make sure the speaker jack isn't set to Digital out instead of analog out.
    Win 8
    Ahh, a new setting. Thanks for that pointer.
    Yeah, they try to cram so much into laptops these days the jacks do double or even triple duty. My father had a very similar problem when he got his Acer Laptop. It supported Dolby Digital Surround Sound 5.1 out but only had the one audio out jack. To use normal speakers you had to switch the jack back to analog stereo out.
So, i got a speaker Sony rdp-x200ipn. I have an Acer Aspire E17 I can connect my speaker to my laptop via bluetooth fine, when it's connected i can test the speaker and it makes the beep sound. When i start itunes, my speaker plays the sound fine, but when i search for example a youtube video...
speaker fill windows 8? in Sound & Audio
Hi, I have an Asus G750 laptop running windows 8 and I was wondering if there is anyway I can hook up my 5.1 home theater system to my laptop and get it to put out of all the speakers? I know there was a setting in windows 7 called "speaker fill" and it would put out through all the speakers,...
Hi, new to this forum. So I recently purchased an internal HDD, placed it inside a HDD enclosure. As soon as I switch it on, it causes a continuous buzzing/interference in the speakers- it seems to be worse when the volume is turned down. The casing is a metal material. I have another seagate...
As the title implies, my speaker is malfunctioning. I have no idea what to do with this problem but I have tried many things. The control panel says it is completely fine and trouble shooting says nothing. Please help me.
Speaker Problem in Sound & Audio
While playing a video or games or any app that has sound... the sound suddenly dissappears if it is too loud. At first I thought it might be the driver... so i replaced HD Audio with Conexant... but the problem still persists, which lead me to believe that it coild be probably the speaker's...
Hi...in my WinXP, i was able to use both headphones and speakers together, but here in Windows 8 I find the option to only use one of them at at time. Is there a setting which can play automatically with headphone/speaker whichever is plugged in or do I need to change the default everytime I plug...
