No sound with headphones?
    Hey guys,
    I have the consumer preview Windows 8, No problems with sound initially until i plugged in my headphones. No sound at all, at first i thought the headphones where broken so i tried 3 other pairs of earphones and still nothing. Anyone have any ideas as to whats going wrong?
    Welcome to the forum. When you right click on the speaker icon in the system tray at bottom right of your screen and select Playback Devices, what are you setting as default?
    Speakers but the headphones dont appear on that menu to pick them..?
    I don't know what brand or model you use, not in your system specs, but you should have options like HDMI, speakers and headphones, or dual headphones, SPDIF... when you right click on one of these, gives you the option to set as default.
    India
    Microsoft Windows 8 Pro 64-bit
    Quote Originally Posted by DMHolt57 View Post
    Hi...in my WinXP, i was able to use both headphones and speakers together, but here in Win8 I find the option to only use one of them at at time. Is there a setting which can play automatically with headphone/speaker whichever is plugged in or do I need to change the default everytime I plug in a device? Thanks
Used my computer after work to listen to music with headphones in and it sounds rubbish, bearable but rubbish. I have Sennheiser headphones that usually sound fantastic, they still do sound fantastic on my phone listening to the same song on Spotify. Anyway, tried Spotify and YouTube and the...
Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and...
Hi. I recently bought a new pc and for the first few days the sound was working fine. This morning, some sound is not working, and some is working fine. Some youtube audio appears to be working and other youtube audio does not work at all. It seems like sound on certain frequency or band is working...
Hi, I have a HCL laptop with Windows 8 Pro x86 installed. Whenever I connect my headphones I don't get any sound from it. I have gone to my "Playback Devices" and selected "Show Disabled Devices" and the headphones are not listed there. What can I do to work around this problem ? I need my...
HP Pavilion dv6-6110us Entertainment Notebook PC laptop running windows 8 upgraded alright. Left the computer on overnight now the sound will not play through the computer speakers unless something is plugged into the headphone or microphone jack. But will play through external speakers... but not...
Hello, I have a Toshiba Laptop c660 with windows 8 professional installed. I can`t make the jack for headphones to work. The jack is not broken because it works on Ubuntu. I installed the driver for my soundboard. Didn`t worked. I unistalled it and i let windows chose the best option for me...
No sound thru headphones in Sound & Audio
On my home-built PC with dual-boot XP and Win8 RP, I can't get any sound thru headphones connected to the tower case's front headphone jack. I get sound through the speakers built into my display, which is connected to the mobo on the case rear panel. Sound comes thru headphones fine in XP. ...
