I have a Turtle Beach Audio Advantage Micro USB Sound Card. It has S/PDIF Optical Out which works great with my surround sound system. I tried installing the drivers on Windows 8 Pro x64 but it keeps saying "Please plug-in USB Audio Device device!". When I go to Device Manager and manually try to browse to the driver to update it I get the following message:
Does anyone know of a way to get the driver to install or know of a small USB sound card with S/PDIF Optical Out that is Windows 8 compatible?
Windows encountered a problem installing the driver software for your device
Windows found driver software for your device but encountered an error while attempting to install it.
Audio Advantage Micro Device
The hash for the file is not present in the specified catalog file. The file is likely corrupt or the victim of tampering.
If you know the manufacturer of your device, you can visit its website and check the support section for driver software.
- Windows 8 Pro x64
- System Manufacturer/Model
- HP EliteBook 8760w
