View problem with forum Threads
Mustang
Australia
Not sure this is the right place for this thread, but couldn't find a place dedicated to forum problem.
Anyhoo, is anyone else having this problem? When I scroll down a thread, after I'm about half way down, the view of the posts stretches to cover the full width of the monitor screen, while the ones above are normal, which covers about two thirds of the screen width.
You can position it so the top half of the screen shows the normal width, and the bottom half shows the full width.
This is a pic of how it looks.
    Windows 7 Ult Reatil & Win 8 Pro OEM
    Built as DIY
    6 core 12 thread & 4 core
    Inel Extreme & Intel standard
    12GB & 8GB
    3 top end SLI linked & onboard
    In built in graphics card & onboard
    24 & 23 inch Samsung LED backlit
    High def
    Corsair Force 128GB SATA3 SSDs in each machine. Plus several external USB3 and eSATA spinner HDs
Same issue here. Could it be a new version of the BB??
    Win 8.1 Pro 64 Bit
    Custom Built: Atomic City Computer
    AMD A4-4000 3.0/3.2Ghz
    MSI FM2-A55M-E33
    8BG of Corsair DDR3 RAM
    On Board
    On Boardi
    Viewsonic 27" VA2703
    1920 X 1080
    Seagate 500GB, Crucial 120Gb SSD
    Thermaltake
    N/A
    Corsair Raptor K40
    Amazon Generic Optical
    56Mbps
    Firefox, Chrome and Opera
    Micro Soft Defender
    Getting this on May 1st:
    AMD A8-6600K
Hello,
What skin and browser are you using?
    Win 8.1 Pro 64 Bit
    MSI FM2-A55M-E33
    On Board
    On Boardi
    1920 X 1080
    Thermaltake
    N/A
    Corsair Raptor K40
    56Mbps
    Micro Soft Defender
    AMD A8-6600K
I have had the same problem over the past few days. - EF Default FF
    Use several different computers during a day, so specs are irrelevant.
Does it do this in IE10 or IE9?
I'm getting it using IE9 default settings on Win7. I'm seeing it right now on this thread as I type this post.
    Built as DIY
    12GB & 8GB
    High def
also seeing some odd placements - ie 10 in metro and desktop - also same with Opera
    Server 2012 / 8.0
    Intel i7 QuadCore 3770k
    Asrock Extreme 4
    16GB Crucial Ballistix
    intel embedded gpu
    Sound Blaster Z
    AOC / Westinghouse
    Plextor pcie msata
    Rosewill Silent Night 500W Fanless / PicoPSU
    open bench - no case enclosure
    Silverstone HEO2 Passive Silent
    logitech washable K310
    logitech wired
    ie / maxthon
    Totally silent. No fans at all.
I'm not seeing it. :confused:
Do you have any add-ons or toolbars installed that could be causing it?
I haven't experienced any such problem so far. Good for me I guess ;)
    Windows 8.1, Windows 7, Linux Mint 14
    HP Pavillion g4
    Intel(R) Core(TM) i3-2330M CPU @ 2.20GHz
    4 GB
    1 GB Radeon Graphics
    Generic PnP Monitor
    1366x768
    500 GB HDD
The add ons I'm using are the same as before and after the problem began. Stuff like Adobe, Java, etc. Nothing out of the ordinary.
I've just noticed it's only seen once I've logged on. If I visit the site but don't log on, it appears normal.
    Built as DIY
    12GB & 8GB
    High def
    Win 8.1 Pro 64 Bit
    MSI FM2-A55M-E33
    On Board
    On Boardi
    1920 X 1080
    Thermaltake
    N/A
    Corsair Raptor K40
    56Mbps
    Micro Soft Defender
    AMD A8-6600K
Same here... no addons other than Photoshop up-loader on FF.
    Win 8.1 Pro 64 Bit
    MSI FM2-A55M-E33
    On Board
    On Boardi
    1920 X 1080
    Thermaltake
    N/A
    Corsair Raptor K40
    56Mbps
    Micro Soft Defender
    AMD A8-6600K
Same issue with IE10.
    Win 8.1 Pro 64 Bit
    MSI FM2-A55M-E33
    On Board
    On Boardi
    1920 X 1080
    Thermaltake
    N/A
    Corsair Raptor K40
    56Mbps
    Micro Soft Defender
    AMD A8-6600K
Fixed... I changed the view setting and it works.
EDIT: I'm now using Metro Blue.. HTH.
And it works fine in FF 16.
Jeff :D
    Win 8.1 Pro 64 Bit
    MSI FM2-A55M-E33
    On Board
    On Boardi
    1920 X 1080
    Thermaltake
    N/A
    Corsair Raptor K40
    56Mbps
    Micro Soft Defender
    AMD A8-6600K
:thumbsup:
Jeff :D
Pleas explain what setting you changed?
Jim :cool:
    ASUS - Home Built
    AMD Phenom II X6 1100T
    ASUS M5A99X EVO
    MSI R6850 Cyclone IGD5 PE
    On Chip
    Corsair 400R
    AVS Gear Blue LED Backlight
    15MB
    NIS, Malwarebytes Premium 2
    Epson V300 Scanner
I found it. I get the error when using Forum Skin - EF Default (CDN).
Jim :cool:
    ASUS - Home Built
    ASUS M5A99X EVO
    On Chip
    Corsair 400R
    15MB
    Epson V300 Scanner
