sfc /scannow found problems but couldn't fix them
    Windows 8.1 x64
    Hello,
    I ran sfc /scannow on my computer (windows 8.1 x64) and it said it found some errors but couldn't fix them.
    I checked the CBS.log and in the summary it said
    CSI Payload Corrupt            amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB
    So I ran DISM /Online /Cleanup-Image /RestoreHealth and it ended up with Error: 0x800f0906.
    I checked the DISM log and here are all the errors:
    2016-06-27 15:29:33, Error                 DISM   DismHostLib: Failed to create dismhost.exe servicing process.
    2016-06-27 15:29:33, Error                 DISM   DISM Manager: PID=1756 TID=3292 Failed to create Dism Image Session in host. - CDISMManager::LoadRemoteImageSession(hr:0x80070057)
    2016-06-27 15:29:33, Error                 DISM   DISM Manager: PID=1756 TID=3292 Failed to load the image session from the temporary location: C:\Windows\TEMP\7F5B2654-2A02-4D9E-9717-025D3B031626 - CDISMManager::CreateImageSession(hr:0x80070057)
    2016-06-27 15:29:33, Error                 DISM   API: PID=1756 TID=3292 m_pDismManager->CreateImageSession failed - CDismCore::CacheImageSession(hr:0x80070057)
    2016-06-27 15:29:33, Error                 DISM   API: PID=1756 TID=3292 InternalExecute failed - CBaseCommandObject::Execute(hr:0x80070057)
    2016-06-27 15:29:33, Error                 DISM   API: PID=1756 TID=2124 CAttachPathCommandObject failed - DismOpenSessionInternal(hr:0x80070057)
    2016-10-23 10:31:58, Error                 DISM   DISM Package Manager: PID=4664 TID=2252 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x800f0906)
    2016-10-23 10:31:58, Error                 DISM   DISM Package Manager: PID=4664 TID=2252 The source files could not be found and download failed. Their location can be specified using the /source option to restore the feature. - GetCbsErrorMsg
    2016-10-23 10:31:58, Error                 DISM   DISM Package Manager: PID=4664 TID=2252 Failed processing package changes with session option CbsSessionOptionRepairStoreCorruption - CDISMPackageManager::RestoreHealth(hr:0x800f0906)
    2016-10-23 10:31:58, Error                 DISM   DISM Package Manager: PID=4664 TID=2252 Failed to restore the image health. - CPackageManagerCLIHandler::ProcessCmdLine_CleanupImage(hr:0x800f0906)
    2016-10-23 10:31:58, Error                 DISM   DISM Package Manager: PID=4664 TID=2252 Failed while processing command cleanup-image. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x800f0906)
    What do I need to do to fix my issues?
    Thanks!
    Windows 3.1 > Windows 10
    that is the Canon Inkjet Printer Driver, and is a common issue with windows 8.1
    Windows 8.1 x64
    Quote Originally Posted by KYHI View Post
    Oh I see.Can you elaborate a bit? What's the cause? How to fix?
Hi on my windows 8.1 x64 PC I am having a lot of problems with programs hanging or not starting etc I ran SFC /Scannow and got this message "Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log....
Hello, Due to explorer.exe crashing after i always try to open a particular folder, i ran the sfc /scannow with admin privileges in SAFE MODE but it says: So i ran the findstr /C:"" %windir%\logs\CBS\CBS.log > "%userprofile%\Desktop\sfcdetails.txt" command.. Here's the file: 66789
I ran into this problem because GTA V always crashes on startup. Rockstar support told me to do the scan. I did it five times with no prevail. None of my other games or programs are affected. I still want to repair the corrupt files. How do I do so. I've included the details .txt file. Please...
I had a problem with BSOD and tried to run sfc /scannow command but found corrupted files and couldn't fix them, I finally resorted to clean installation, today I received a new BSOD with error 0x0c000021a, and tried again sfc /scannow and message appeared FOUND "CORRUPTED FILES, BUT COULDN'T FIX...
During sfc /scannow it gave me a error about a corrupt file, heres the CBS.log: CBS
Microsoft Windows (c) 2012 Microsoft Corporation. All rights reserved. C:\Windows\system32>sfc/scannow Beginning system scan. This process will take some time. Beginning verification phase of system scan.
Sfc /scannow found corrupt files but was unable to fix some. The log does not say whats wrong just stops. Not really sure where to go from here. Help please.
