Switching Between Users Problem
    UK
    Windows 8.1 64 bit
    I have 2 Windows 8.1 PCs and have the same problem on both. When I switch from one user account to another then back to the original account, I just get the rotating circle and can't do anything. The problem is solved by logging off and on again. SFC /SCANNOW shows no problems.
    Has anyone any ideas on what may be the problem?
    UK
    Windows 8.1 64 bit
    Any ideas?
    Hello Steve,
    Could be something running that's causing it to hang?? You might see how switching between users works while troubleshooting with a clean boot.
    Troubleshoot Problem with Clean Boot in Windows 8
    If that doesn't yield any results, then a repair install should be able to sort it without losing anything.
    Repair Install Windows 8
Switching users in WIN8.1 issue. in User Accounts and Family Safety
When I switch users from the Start Menu, the screen just goes black for a few minutes before the logon screen eventually appears. The wait seems to be getting longer and longer. I have the Classic Shell start menu installed. This used to work fine. Thanks for any suggestions.
Solved Switching Users without password in User Accounts and Family Safety
I have set up 2 users; 1 as administrator (me) and 1 for my wife. It is a home computer and we do not require password protection. I am the normal user and have managed to set up so that I login within having to enter password. However when my wife uses the computer the Start-up screen is me and...
I have download a bad files and he have a ''Malware'' or virus, My Malware or my anti-virus have delete the infection but the document I can't erase and he have nothing in ? If he have a clue for that, give me, I appreciate ! :D Regards
OS: Windows 8.1 Pro. Problem: Sometimes I cannot switch between 2 languages. I use left (shift+Alt). It "fixed" only when I reinstall the language that I cannot switch into or when I re-log into windows. I had the same problem In windows 7 and I fixed it by creating new keyboard...
Does anyone know of a hack for this? It's not new to Win8 and is by design, according to the definition of the error # left in the applog (see below). This seems like the sort of thing that there would be a workaround for, but I haven't found it yet if so. It's a definite annoyance.
Hi everyone. My first visit here now I'm in the Win 8 club. I have read various other threads and tutorials that offer varying degrees of 'fix' to this, some highly technical/registry editing and all sorts I'm not comfortable with. This is a brand new machine with Windows 8.1. I have a SSD...
Read more at source: Microsoft to deliver fix for Surface RT users hit by application-update problems | ZDNet
