Repairing problems detected by sfc
layman
After running sfc /scannow the CBS.log reads :
can't repair bootmgfw.efi.mui, version 6.3.9600.17031 - file missing;
can't repair utc.app.json, version 6.3.9600.17747 - hash mismatch;
can't repair telemetry.ASM-WindowsDefault.json, version 6.3.9600.17747 - hash mismatch,
can't repair AMD64\CNBJ2530.DPB, version 6.3.9600.17415 - hash mismatch
I've tried Dism/Online/Cleanup-Image/RestoreHealth but no success.
The Telemetry files mentioned in KB3068708 are no longer available at Microsoft site.
I can't enter Command Prompt under "System Recovery" as the "Advanced Start Up" Screen shows only two buttons - Continue & Turn Off PC, the other two buttons (Use another Device for Start up & Troubleshooting) are missing. I also notice bootrec.exe is missing.
All these problems were detected after I tried to Install Windows 10 upgrade, both thru "Windows Update" & "using ISO image created with MediaCreationTool" - Installation failed at 24% with "Something Happened". The setuperr.log was blank.
Any solutions?
    Windows 10 Home (64-bit)
    ASUS K55N -DS81
    AMD A8-4500M
    ASUSTeK Computer Inc
    4GB
Please upload the cbs.log so we can have a better look at it.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
After running "PCFixit" Program the "bootmgfw.efi.mui" missing has been rectified, but the problem of "Telemetry" files remain. How to attach CBS.log? I find only attach "image"/"Video" button on toolbar. Also after running the solutions suggested by "genset" the "Recovery" option has been restored. But two important files :bootrec.exe & install.wim are still missing
    ASUS K55N -DS81
    AMD A8-4500M
    4GB
The temeletry is a false positive that came with an update for windows 10.
Same for the utc.app.json.
To attach the cbs.log:
When you create a new quick reply scroll a little bit down until you see the 'Go advanced' button on the right of the quick reply.
Click on this button so you'll get the advanced options, scroll down again until you see the 'manage attachment' button in the middle of the additional options which you'll find while scrolling down.
Click on manage attachment, a popup opens with your attachment, in the right upper corner is a button, click on that button to add files from your pc.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
