Weird settings for taskbar when right click icons!!
    How can I fix this?
    Prince Rupert
    Windows 8.1 Pro 32-bit (6.3, Build 9600)
    I'm having the same issue with my task bar but slightly different, I will upload a picture to show what it looks like right now and maybe someone can help me find out how to fix it? this is how it was when I installed windows 8.1 Pro on my HP desktop computer from DVD.... I changed no settings, How can I put it back to normal?
Ok so I tried to use small icons but the "Show hidden icons" Arrow is a bit lower than usual here is a screenshot http://i62.tinypic.com/2ijgt3n.png
I have a brand new Dell Inspiron 7000 2-in-1 with Windows 8.1. When I right-click on an icon on the taskbar, the context menu has a purplish background with purple text. It is basically unreadable. In addition, the 'Unpin' context choice has the pushpin moved to the right so it's over the word...
I installed yesterday Windows 10 in my laptop. It seems there were a problem after installation, and it reverted back to Windows 8.1. I decided to do a clean install: deleted partitions and installed without importing anything. But even without import, now the context menu in taskbar looks...
http://puu.sh/cMapi/41f3e0deff.png http://puu.sh/cManO/effacca2ff.png I don't know what they are called and the title for the thread was limited so sorry for the broken English but after windows 8 forced the windows 8.1 update, all text in firefox went weirdly small but that isn't as...
Solved weird picture Icons in General Support
Had win7 loaded win 8 at Christmas time. Previously when I opened my "My Pictures" the icons were a small picture. today I noticed that they had all changed to a generic camera. I messed around with the win 8 photo viewer and now they look like a drawing of a mountain range with the sun behind...
Hi, I am new to windows 8, and have encountered a problem. It appears that the icons that normally appear when you right-click a tile in the metro interface have been replaced with weird symbols (see bottom left corner of attached picture). I have used the refresh option in the PC settings...
