Help determining system bottleneck
rct2guy
St. Louis, MO
Hey all,
I've been noticing some slowdowns on my ~3 year old system, and am looking to replace whatever components I need to, but I want to know how to identify which part is slowing my system down the most.
Applications take a little too long to load, and I notice stuttering in games (Grand Theft Auto V and The Sims 3). I think these issues could easily be caused by any component being outdated, so I want to know what the best way would be to identify a bottleneck in my setup. I've used the Task Manager to monitor performance and received results that were not particularly useful.
Here are my system specifications:
Processor: Intel Core i5-2500k (LGA 1155)
Motherboard:
Gigabyte GA-Z68X-UD3H-B3
Memory: 4GB (x2) Corsair 1600MHz
Graphics card: EVGA NVIDIA GTX 570
Hard drive: 1.3TB Samsung 5200 RPM
In my opinion, my hard drive needs to be replaced by an SSD, but I'm not so sure it's the root of all of my stuttering and slow-downs. My graphics card is also aging, but obviously that wouldn't explain my slow applications.
Any ideas? I appreciate any feedback and would be more than happy to provide further information. Thanks much for the assistance!
    Windows 10 Pro (64-bit)
    8GB (4GB x2) Corsair 1600MHz
    EVGA NVIDIA GTX 570
    ASUS VG248QE, Dell E173FP
    1920x1080, 1280x1024
    Samsung 1.3TB, 5200 RPM
    Antec 620w
    Bit Fēnix Survivor
    Bit Fēnix Specter (x2)
    Logitech MX 5500
    Razer DeathAdder Chroma
    95 MB/s
    Windows Defender, Malwarebytes
I personally think that your amount of ram (2 sticks for 4gb ram) is quite low for big games like GTA V.
If your motherboard can handle 8GB-16GB of ram, I suggest upgrading it. Also, just in case you don't know the true meaning of bottlenecking, I suggest you watch this to get a better understanding of it:
https://m.youtube.com/watch?v=DAgpvWc4VBM
(I'm posting the video for educational purposes ONLY. I am in no way affiliated with JayzTwoCents)
I hope this helps!
    Inspiron M731R (5735, Late 2013)
    1.70 GHz AMD A8 5545M Elite Quad Core
    No idea
    8GB DDR3
    AMD 8510G Radeon(tm) HD Graphics
    Realtek
    17.3" Inch Display
    1600 x 900
    500GB 6GB/s Crucial BX100 SSD
    Blue Aluminum Finish
    Laptop Fan (Currently Unknown Name)
    Came with it
    Utech Smart Optical Gaming Mouse US-D4000-GM
    Google Chrome / Safari (On my iPod and iPad)
    Vipre InternetSecurity2015/MalwareBytes Anti-Malware PREMIUM
Hmm, I never thought of that; My machine does seem to get close, but never maxes out, on RAM usage. Since RAM isn't too expensive, I'll definitely look into purchasing more.
Still, would my problems be caused by my slow hard drive and/or benefit from an SSD?
    EVGA NVIDIA GTX 570
    Antec 620w
    Bit Fēnix Survivor
    Logitech MX 5500
    95 MB/s
Is this a 32 or 64 bit OS? You should update the system specs to show this.
If 32 bit 4 GB RAM is the limit, even if your hardware will support more.
    Windows 7
Yes. You WILL benefit from a SSD. Especially a 256GB-2TB one. If I were you, I would use hybrid storage. SSD for the OS and HDD for storage like games and folders.
And LMiller7 is correct. Although, I thought that the 32Bit maximum was 3GB not 4GB. But 4GB does seem right.
    No idea
    8GB DDR3
    Realtek
    17.3" Inch Display
    1600 x 900
    Came with it
32 bit client versions of Windows have a 4 GB RAM limit. This is a license limit enforced by the kernel. But due to address space sharing not all of this 4 GB is available for RAM. Depending on hardware roughly 3 - 3.5 GB will be available. If RAM is used by the video system this will be further reduced.
    Windows 7
Sorry, I guess I wasn't totally clear: I'm running a 64-bit OS, which supports my 8GB of RAM.
That is my plan. I think I'm going to get a 480GB SSD and couple it with my 1.5TB drive.
Thanks much for all of the advice, and if anyone has any further suggestions, I would love to hear them.
    EVGA NVIDIA GTX 570
    Antec 620w
    Bit Fēnix Survivor
    Logitech MX 5500
    95 MB/s
Next obvious one would be GPU, that processor can feed much better one without problems. Processor can take some OC if you are so inclined.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
