Problem Chkdsk impossible to read
    Hello, i'm new so be a little bit easy on me
    So i launched a chkdsk F: /F on my SDXC card (64GB) and it's been 15 hours and the command prompt is unreadable it is still running but i don't know what to do wait or take down the command prompt.
    Thanks for any help what so ever Click image for larger version
    Trying to Sith things out
    Bamberg Germany
    Windows 10 Pro 64 bit
    It looks like you used the v/ switch:
    /v Displays the name of each file in every directory as the disk is checked.
    Parameter Description
    <Volume> Specifies the drive letter (followed by a colon), mount point, or volume name.
    [<Path>]<FileName> Use with file allocation table (FAT) and FAT32 only. Specifies the location and name of a file or set of files that you want chkdsk to check for fragmentation. You can use the ? and * wildcard characters to specify multiple files.
    /f Fixes errors on the disk. The disk must be locked. If chkdsk cannot lock the drive, a message appears that asks you if you want to check the drive the next time you restart the computer.
    /r Locates bad sectors and recovers readable information.The disk must be locked. /r includes the functionality of /f, with the additional analysis of physical disk errors.
    /x Forces the volume to dismount first, if necessary. All open handles to the drive are invalidated. /x also includes the functionality of /f.
    /i Use with NTFS only. Performs a less vigorous check of index entries, which reduces the amount of time required to run chkdsk.
    /c Use with NTFS only. Does not check cycles within the folder structure, which reduces the amount of time required to run chkdsk.
    /l[:<Size>] Use with NTFS only. Changes the log file size to the size you type. If you omit the size parameter, /l displays the current size.
    /b NTFS only: Clears the list of bad clusters on the volume and rescans all allocated and free clusters for errors. /b includes the functionality of /r. Use this parameter after imaging a volume to a new hard disk drive.
    /? Displays help at the command prompt.
    No i didn't use that switch actually you can see what i used in the screenshot chkdsk F: /F that's all after windows began to say cluster of this file are dammaged replacing failover cluster renamed xxxxxx then next time it began to show a lot of folders and then this anarchy.
    Bamberg Germany
    If it's repairing just let it run, I just see a lot of file addresses in your screenshot. I personally never used the F switch before but it looks like it's just printing verbatim as it moves stuff around.
    Yeah but repairing takes a lot of time plus those file adresses are always the same in the command prompt it keeps repeating itself and last how much time you think this would take because i'm at 16 hours of repairing so i don't know how much time to wait for
    Bamberg Germany
    If you stop it windows should finish what ever it's moving(so as not to corrupt the files). You could then try another switch to "quickly" check it without repairing, to see how far you are. Then use one of the faster switches depending it the card is FAT or NTFS.
    But how can i stop it safely because i don't know the way like "safe" but the card system is in ExFat
    Bamberg Germany
    Try ctrl+c.
    And before starting again read this: [GUIDE] Using chkdsk to fix a corrupted SD card - Android Forums at AndroidCentral.com
    You probably know the stuff, but a refresher is always good
    Ok but i tried it a lot of time it doesn't work i think it's because it is in the stage that you can't possibly stop
    Bamberg Germany
    I really don't know what else to try to safely stop it. But 16 hours is a long time, especially for flash drive(nand).... maybe someone else can help, sorry
Page 1 of 2 12 LastLast
Solved Chkdsk problem, dual boot Win7/8.1 in Performance & Maintenance
I have Windows 7 and 8.1 dual booted on a native 8.1 laptop. Whenever I start my Windows 7 installation, it tries to run chkdsk on all of my partitions. I have attempted to disable fast startup in Windows 8.1, but it still runs chkdsk on Windows 7 boot. Any solutions?
4937949380 I have searched the internet for solutions and I already tried chkdsk. It finished but after the process I checked and windows tells me that there are still errors. Just want to know if there is any solution to this kind of problem.
I have tried pretty much everything to install the latest Windows 8.1 Update, including fixes for Windows Update, manual installation, etc. Literally nothing has helped. I have now spent at least 10 HOURS trying to get this botched update to install. Is Microsoft firing all their QA guys to save...
Hi, I am a bit of a newbie to uTorrent. As it says in the thread subject I am experiencing that when downloading with uTorrent the general browsing is either very slow or impossible (page not responsive). I have recently found a thread that suggests a few tweaks that could help, I have...
Almost impossible to LOGIN in Win8!!!! in User Accounts and Family Safety
Hi Just bought a PC with Win8 installed and get crazy with this PC. Whenever I type a letter (or even any keyboard) in the password field, this round-dots image is turning for 10 minutes before displaying again the password field..... And the problem is starting again and again...... PLEASE...
impossible to install on eeepc in Installation & Setup
My test computer is an eeepc901 with a 4 gb ssd and an 8gb sd card. I first attempted install fresh on my ssd over the existing Windows Xp. This is impossible as Windows 8 needs close to 6 giga bytes just to install. Wasn't this version supposed to be tablet and netbook friendly? So next I...
Hi, was installing Win8-X64 and when asked for a driver for my Revo, Win8 recognizes the OCZ driver but says that driver is no good. OCZ does not have a driver yet. So i had to abort the installation. Now i want to install Win8 on my Foremay SSD and i am prompted to give the activation...
