Problem Chkdsk impossible to read
TheFullmetal
Hello, i'm new so be a little bit easy on me
So i launched a chkdsk F: /F on my SDXC card (64GB) and it's been 15 hours and the command prompt is unreadable it is still running but i don't know what to do wait or take down the command prompt.
It looks like you used the v/ switch:
/v
Displays the name of each file in every directory as the disk is checked.
Parameter
Description
<Volume>
Specifies the drive letter (followed by a colon), mount point, or volume name.
[<Path>]<FileName>
Use with file allocation table (FAT) and FAT32 only. Specifies the location and name of a file or set of files that you want chkdsk to check for fragmentation. You can use the ? and * wildcard characters to specify multiple files.
/f
Fixes errors on the disk. The disk must be locked. If chkdsk cannot lock the drive, a message appears that asks you if you want to check the drive the next time you restart the computer.
/v
/r
Locates bad sectors and recovers readable information.The disk must be locked. /r includes the functionality of /f, with the additional analysis of physical disk errors.
/x
Forces the volume to dismount first, if necessary. All open handles to the drive are invalidated. /x also includes the functionality of /f.
/i
Use with NTFS only. Performs a less vigorous check of index entries, which reduces the amount of time required to run chkdsk.
/c
Use with NTFS only. Does not check cycles within the folder structure, which reduces the amount of time required to run chkdsk.
/l[:<Size>]
Use with NTFS only. Changes the log file size to the size you type. If you omit the size parameter, /l displays the current size.
/b
NTFS only: Clears the list of bad clusters on the volume and rescans all allocated and free clusters for errors. /b includes the functionality of /r. Use this parameter after imaging a volume to a new hard disk drive.
Displays help at the command prompt.
    Cliff's Black & Blue Wonder
    Intel Core i9-9900K
    ASUS ROG Maximus X Hero
    hanteks Enthoo Pro TG
    Trust GTX THURA
    Trust GTX 148
    25+/5+ (+usually faster)
    Edge; Chrome; IE11
    Router: FRITZ!Box 7590 AX V2
No i didn't use that switch actually you can see what i used in the screenshot chkdsk F: /F that's all after windows began to say cluster of this file are dammaged replacing failover cluster renamed xxxxxx then next time it began to show a lot of folders and then this anarchy.
If it's repairing just let it run, I just see a lot of file addresses in your screenshot. I personally never used the F switch before but it looks like it's just printing verbatim as it moves stuff around.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Yeah but repairing takes a lot of time plus those file adresses are always the same in the command prompt it keeps repeating itself and last how much time you think this would take because i'm at 16 hours of repairing so i don't know how much time to wait for
If you stop it windows should finish what ever it's moving(so as not to corrupt the files). You could then try another switch to "quickly" check it without repairing, to see how far you are. Then use one of the faster switches depending it the card is FAT or NTFS.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
I really don't know what else to try to safely stop it. But 16 hours is a long time, especially for flash drive(nand).... maybe someone else can help, sorry:(
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Yeah i think too nah i may stop it unsafely since the risk are only data that a saved before doing anything then maybe retry it later if the card is still working properly after that stop
If your system can still "read" it copy the files, then delete the card before trying chkdsk next time, maybe that can speed things up.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Try-
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
