Who can help me to fix this problem (regedit)
    8.1
    I just click on that attachment file that i upload. Now I can't access to regedit any more. what can i do, who can fix this problem for me please. sorry for my bad English. Thank you
    aaWindows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\*\shell\runas]
    @="Grant Admin Full Control"
    "NoWorkingDirectory"=""
    [HKEY_CLASSES_ROOT\*\shell\runas\command]
    @="cmd.exe /c takeown /f "%1" && icacls "%1" /grant administrators:F"
    "IsolatedCommand"="cmd.exe /c takeown /f "%1" && icacls "%1" /grant administrators:F"
    [HKEY_CLASSES_ROOT\exefile\shell\runas2]
    [HKEY_CLASSES_ROOT\exefile\shell\runas2\command]
    [HKEY_CLASSES_ROOT\Directory\shell\runas]
    [HKEY_CLASSES_ROOT\Directory\shell\runas\command]
    @="cmd.exe /c takeown /f "%1" /r /d y && icacls "%1" /grant administrators:F /t"
    "IsolatedCommand"="cmd.exe /c takeown /f "%1" /r /d y && icacls "%1" /grant administrators:F /t"
    Who can help me to fix this problem (regedit) Attached Files
    Hello Leonboy, and welcome to Eight Forums.
    That .reg file would only add Grant Admin Full Control to your context menu, and nothing more. If you used the context menu on a file, it would change the owner of the file to be Administrators, and grant the Administrators group full control (access) of the file.
    Did you do anything else?
    If you like, you could do a system restore using a restore point dated before this happened to undo it.
    System Restore - How to Do in Windows 8
    8.1
    So why I can't acces to regidit? Thank you.
    Got me since nothing there would be a reason, but a system restore should sort it for you.
My computer has two separate drives: A 120GB SSD and a 1 TB HDD. Windows 8 is installed on the SSD and intend to use this drive (C: just to store the operating system). I want everything else stored of the HDD which is labeled as my D: drive. To avoid program files from being installed on my C:...
How do I UN-merge a previously-merged .reg file from the registry? Windows 8.1
GPEdit vs RegEdit? in Performance & Maintenance
Hi, I'm not sure if this has been asked before but is it generally better to tweak, disable and hide Windows features via GPEdit (Group Policy Editor) or RegEdit (Registry Editor) given the Windows version has both for the user to choose from? I'm asking both from a security stand point and...
Hi Shawn, Still struggling to come to terms with my Win 8.1 Pro 64 bit... Your help in clarifying the (regedit) issue below would be very much appreciated. 1. I backup a registry key (say HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Icons) 2. I delete that...
Solved Windows 8 WMC regedit question in General Support
Hi I finally decided to make a account after lurking here for a bit, but I just have a quick question to anyone who has the Windows 8 with windows media center pack. I was going back to just the w8pro following this tutorial ...
can't open regedit in General Support
I was trying to change modify on something that was on a website. Remove ballon on taskbar. Here's the link: How to Stop Taskbar Balloons | eHow.com The balloons are still there. Now I can't open the regedit. Nevermind I open it by going to search C:\Windows\system32, can you find regedt32.exe but...
The picture shows how to protect System Restore using WinPatrol. Here is the help page it came from- BillP Studios - WinPatrol Registry Monitoring Scripts You can add the registry code manually, if you wish to. As always, be careful editing the registry. Back it up first.:)
