Who can help me to fix this problem (regedit)
Leonboy
I just click on that attachment file that i upload. Now I can't access to regedit any more. what can i do, who can fix this problem for me please. sorry for my bad English. Thank you
aaWindows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shell\runas]
@="Grant Admin Full Control"
"NoWorkingDirectory"=""
[HKEY_CLASSES_ROOT\*\shell\runas\command]
@="cmd.exe /c takeown /f "%1" && icacls "%1" /grant administrators:F"
"IsolatedCommand"="cmd.exe /c takeown /f "%1" && icacls "%1" /grant administrators:F"
[HKEY_CLASSES_ROOT\exefile\shell\runas2]
[HKEY_CLASSES_ROOT\exefile\shell\runas2\command]
[HKEY_CLASSES_ROOT\Directory\shell\runas]
[HKEY_CLASSES_ROOT\Directory\shell\runas\command]
@="cmd.exe /c takeown /f "%1" /r /d y && icacls "%1" /grant administrators:F /t"
"IsolatedCommand"="cmd.exe /c takeown /f "%1" /r /d y && icacls "%1" /grant administrators:F /t"
  • GrantAdminFullControl.reg
Hello Leonboy, and welcome to Eight Forums.
That .reg file would only add Grant Admin Full Control to your context menu, and nothing more. If you used the context menu on a file, it would change the owner of the file to be Administrators, and grant the Administrators group full control (access) of the file.
Did you do anything else?
If you like, you could do a system restore using a restore point dated before this happened to undo it.
http://www.eightforums.com/tutorials/4692-system-restore-how-do-windows-8-a.html
Got me since nothing there would be a reason, but a system restore should sort it for you.
