Disable power off while on battery
    Windows 8.1 Pro Pack x64
    Since I don't use my computer as much anymore, I've noticed that when I put it to sleep and leave it idle with the power cord unplugged, it shuts off after 5-6 days. When I boot it up following this, it's obvious that it just powered out, it didn't shut down. I put it to sleep like most people and I don't want to keep the cord connected all the time, since it will kill my battery in the long term, nor do I want to worry about un-connecting and re-connecting when I'm not planning on using it.
    My question is: if I put it to sleep and the battery level gets low, is there a way to program it to hibernate instead, or at least shut down safely? I've checked advanced power options and the answer doesn't seem to be there.
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    I don't think so. If it's in sleep mode Windows isn't running so those settings don't come into play anyway.
    You should be able to set the power options so the system hibernates after a set period of time.
    Trnava
    Win 8.1.1 Pro x64
    Quote Originally Posted by Malickfan86 View Post
    Not really. I have the cord plugged in for 3 years and the battery is at 99% capacity. The battery is being worn out, when it is being recharged, not when it is being plugged in, it will just recharge and that is it.
    Actually, it is. Set the critical batter level to 1% and then set the critical battery action.
I have just purchased a new HP Spectre x360 Convertible 13 laptop last week with Windows 8.1 installed as the operating system. It is the first time I have owned anything with Windows 8.1. Anyway, I am wanting to adjust the Critical Battery Level in Power Options to something lower than the...
Hello Everyone, I need your help to troubleshoot why my desktop PC randomly loses power. This happens every few days, sometimes multiple times. Without warning, the computer completely loses all power. The case fans stop for a moment. The computer then beeps and reboots. There is never any...
I want to disable the "allow this device to wake the computer" to prevent the accidental pressing of the keyboard waking up the PC. This option doesn't exist though, like it does with the USB mouse. Is there a way around this? thanks
hi my helping friends, i had windows 7 earlier , the rare of battery consumptions was 10 -14 watt hour as shown by battery meter gadget . then i installed windows 8 and installed windows 8 gadget pack then installed the battery meter gadget but the rate of consumption of battery was always 18 -22...
Anyone having battery-power issues? in Performance & Maintenance
I upgraded to 8 a few days ago (doing a clean install by usb after downloading Windows through the Upgrade Assistant) and everything about Windows 8 itself is great! Except that my battery-duration is really suffering. Before (and by before I mean, that same day, but using windows 7) I used to have...
