"sfc/scannow can't fix some of them" help....
that error was cause by a windows update - it is an unused print driver - MS has not corrected the Hash - so it is seen as the wrong file.
many have just removed the file.. Many know it cause no harm and leave it be..
if you run the dism- restorehealth cmd = you will find other issues also caused by windows update
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
i searched the net on how to do it.. and when i typed
"DISM.exe /Online /Cleanup-image /Restorehealth"
it says the option is unknown
    windows 8 pro
You could try uninstalling update KB3022345
See if that does the trick, it did for me.
Windows have recently updated KB3022345 with a fix: KB3068708
    Windows 8.1 update 1
    Dell Inspiron 15R special edition
    Intel Core i5-3210M CPU @ 2.50GHz
    Intel HD Graphics 4000
    Avast
I wasn't able to find both KB3022345 and KB3068708 on "view installed updates" on "uninstall a program" on control panel
    windows 8 pro
