Best Method to Create System Recovery
thunderclap
I just re-installed Windows 8.1 on my ASUS X202E laptop. It was long process since it originally came with Windows 8, so after I installed that I had to install all the patches and updates before I could even get Windows 8.1 from the Windows Store. Then I had all those patches and updates. All-in-all it was a 9-hour ordeal, something I'd like to avoid in the future.
The computer originally came with a mechanical drive, one I swapped for an SSD. Since I never cloned the original drive I used one of my OEM Windows 8 discs from another system I have. Since the activation key is hard coded into the system this wasn't a problem.
What I would like to do now, before installing any other software, is create a Recovery Disk/System Image onto a USB flash drive so that if I ever need to re-install again I can cut that 9 hours down. What is the best method of doing this?
Since I don't have a Recovery Partition the method MS outlines is out, and when I try to create a System Image using this tutorial I'm told the flash drive is not a valid backup location. (It's a 16GB flash drive).
How do I do an exact copy of the current "vanilla" install (and I use vanilla loosely) onto a flash drive so that I can restore later if need be?
    Windows 8.1 Update 2 x64
    Core i5-3570 Ivy Bridge
    ASRock Z77 Exteme4
    Corsair Vengeance 16GB
    EVGA nVidia 760
    Sound Blaster X-Fi Titanium Fatal1ty
    ASUS 23"
    SanDisk Extreme SSD 240GB (OS)
    Western Digital 1TB (Data)
    Hitachi 2TB (Media Drive)
    Corsair HX Professional Series 750-Watt
    Corsair Carbide Series 400R Mid Tower
    Corsair Hydro Series H80 High Performance Liquid CPU Cooler
    Logitech K800
    Logitech T400
If you've just re-install windows and you have no third party software installed then 16 gb is enough. A Valnilla Windows 8 will take around 8~10GB for the backup image. However, it is better if you have an external HD to backup so it is a lot faster.
Install: Macrium Reflect Free
run it, and backup to your USB stick.
Make a Macrium Rescue disk on a USB and boot up from it in case you want to restore.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
