CPU temperature going up after replacing hard drive!
    Hello
    A few days ago, i was changed laptop HDD with a SSD (and reset Windows).
    But now the CPU temperature is always high, Even when no program is not open:
    Please help me to solve this issue
    Thank you
    Windows 8 64 bits Pro with Media Center
    this is not the cpu temprature which you shows here. that is the system utilization. and if you complaining about high utilization graph without any processing then it must be some background process working. in windows 8, schedule error checking always ON. which is running while idel mode.
    for cpu temp, you need to installed some app for this. I recomed piriform speccy sysetm info app.
    Quote Originally Posted by I AM LEGEND View Post
    Thank you
    I know this, the photo mean is, the CPU clock always is maximum and system utilization just is on a core.
    I can see the CPU temp By "AIDA64 Extreme", it is always more than 60oC!
    I asked this question because the body of the laptop is always hot, and fans work with maximum speed!
    Windows 8.1 Pro/LinuxMint/Mac OS X
    Quote Originally Posted by MasoudM View Post
    Thank you
    If you figure out what is causing the mass amount of CPU usage and you fix it. It very well may fix your over heating issue. What I assume you are looking for.
    In that case look under your process/service tabs in task manager, you can get a better idea as to what is running.
    WAX
    Quote Originally Posted by LegacyOfWax View Post
    WAX
    Thank you
    In the processes tab "System" and "System interrupts" are the most CPU.
    I think the problem is the "System" :
    ok, have you tried booting into safe mode to see if you still have the High CPU usage?
    If you don't know how you can try going to the link below and following 1 these steps
    5 Ways to Boot into Safe Mode in Windows 8 & Windows 8.1
    In the safe mode CPU clock is minimum, but temp and fan speed is high!
    All that is showing is what is being used in % from your CPU not temperature. When it says speed ( what you have highlighted in red) is not fan speed. That is showing clock speed.
    I would deal with the amount of CPU usage your system is using first.
    Find out what services are chewing up that CPU and try fixing that.
    You can try doing a system repair on it. May help solve the issue.
    WAX
    WAX
    Thank you
    I know that, my laptop CPU minimum clock is 2.4 and maximum is 3.4
    In normal mode clock must be on 2.4
    Hi
    My problem was solved with the use of this method(Post 2 of this topic):
    HP Elitebook 8560p Won't Shutdown | NotebookReview
Any idea why my SSD is listed as a 'Hard disk drive' instead of 'Solid state drive' as in your screenshots above? I am running W8 Pro x64 RTM from Technet. In Device Manager my SSD shows as a 'Samsung SSD 830 Series SCSI Disk Device'. I wonder if it's being on a Marvell controller might be the...
Can you save to hard drive and One Drive at Same Time?
I am running Windows 8.1 and it appears that my hard drive needs to be replaced. When the machine is turned on, frequently there is a slight screech and I feel itís best to replace the hard drive. How do I make an exact bootable copy of the hard drive on a new hard drive and simply replace...
Hard drive crash enquiry My hard drive recently crashed on my desktop running XP and due to the discontinuation of support for XP, I decided to upgrade with a new motherboard, memory, hard drive etc., now running Win 8.1, which has been working fine so far. My problem is that there is...
I'm booting off my SSD which is drive C:\ and I have games and programs on an extra hard drive which was origanally drive H:\ but after a restart it switched to I:\ and when I go into Disk Management to change it Drive H:\ isn't there.
I have a 2TB Western Digital My Book Essentials, it's filled with tons of old photos, movies, docs, games, and I'm scared to think of what else. The SATA to USB connector broke on it, so I took the drive apart and put it inside my computer. I opened up device manager because it wasn't showing up...
So the same issues i had in Windows 8 Release Preview too and i was hoped to be fixed in Windows 8 RTM but still the same! So the issue about HDD is that i'm using two hard drives; one is Western Digital which is primary with Windows 8 installed on it and the other is Hitachi which i use it for...
