CPU temperature going up after replacing hard drive!
MasoudM
Hello
A few days ago, i was changed laptop HDD with a SSD (and reset Windows).
But now the CPU temperature is always high, Even when no program is not open:
Please help me to solve this issue :rolleyes:
Thank you
    ASUS N550JV
this is not the cpu temprature which you shows here. that is the system utilization. and if you complaining about high utilization graph without any processing then it must be some background process working. in windows 8, schedule error checking always ON. which is running while idel mode.
for cpu temp, you need to installed some app for this. I recomed piriform speccy sysetm info app.
    Windows 8 64 bits Pro with Media Center
    Dell Inspiron N4050
    2.1 Ghz Intel mobile 950
    Dell 02JCHC
    4gb (2x2gb) DDR3 1333
    Intel(R) HD Graphics Family
    1366x768
    4mbps
Thank you
I know this, the photo mean is, the CPU clock always is maximum and system utilization just is on a core.
I can see the CPU temp By "AIDA64 Extreme", it is always more than 60oC!
I asked this question because the body of the laptop is always hot, and fans work with maximum speed!
    ASUS N550JV
Thank you
If you figure out what is causing the mass amount of CPU usage and you fix it. It very well may fix your over heating issue. What I assume you are looking for.
In that case look under your process/service tabs in task manager, you can get a better idea as to what is running.
WAX
    Windows 8.1 Pro/LinuxMint/Mac OS X
    Intel i5
    MSI Z87
    8GB Kingston
    LG
    SSD-30GB
    SSD-240GB (Root Drive C:\)
    HDD-1Tb
    Logitec
    Logitec
WAX
Thank you
In the processes tab "System" and "System interrupts" are the most CPU.
I think the problem is the "System" :
    ASUS N550JV
    Intel i5
    MSI Z87
    8GB Kingston
    LG
    SSD-30GB
    HDD-1Tb
    Logitec
    Logitec
All that is showing is what is being used in % from your CPU not temperature. When it says speed ( what you have highlighted in red) is not fan speed. That is showing clock speed.
I would deal with the amount of CPU usage your system is using first.
Find out what services are chewing up that CPU and try fixing that.
You can try doing a system repair on it. May help solve the issue.
WAX
    Intel i5
    MSI Z87
    8GB Kingston
    LG
    SSD-30GB
    HDD-1Tb
    Logitec
    Logitec
WAX
Thank you
I know that, my laptop CPU minimum clock is 2.4 and maximum is 3.4
In normal mode clock must be on 2.4
    ASUS N550JV
