windows8use
Banned
Hello I get a problem with sfc /scannow.
Last time I run sfc /scannow and it cannot fix some system files because store is corrupted, so I run dism /online /cleanup-image /restorehealth then later sfc /scannow fix the files. For second time (after some weeks) I run sfc /scannow to make sure no corrupted files and sfc /scannow find it and again cannot fix because store corrupted, so I run dism and later files fixed. Today I run the sfc again and found corrupted files and again cannot fix because store is corrupted (dunno why) and I need to run dism again and sfc fixed corrupted files.
Why each time I need to run dism so the sfc will only work?
- Windows 8.1 Pro 64-bit, Windows 10 64-bit
- Computer type
- PC/Desktop
