Power Consumption With Hybrid Shutdown?
    St. Augustine
    Does a laptop on battery consume any power with hybrid shutdown? Considering the Windows 8.1 Fast Boot Enabled/Hybrid Shutdown feature.
    I was rather surprised to see the significant battery power drain during sleep as referenced in the attached article but I can't seem to get a definitive answer regarding the Hybrid Shutdown state.
    How Much Battery Life Does Sleep Mode Really Drain?
    Windows 8 x64
    Sleep and hybernation are not meant for laptops because during suspension and/or sleep the computer still uses power, altough you can't see or hear it doing that. Sleep and hybrid shutdown are practically the same thing. When you hybrid shutdown Windows 8 it's only being suspended which is exactly the same as sleep mode. That's why it's using power.
    In order to save power you need to turn off hybrid shut down. Look here about how to disable it: How to Disable Hybrid Boot and Shutdown in Windows 8
    I could show you the same thing but my Windows is entirely in Bulgarian and you wouldn't understand anything.
    St. Augustine
    Quote Originally Posted by rado84 View Post
    That's funny, but you're right, it would all look greek to me. No problem though as I know the process well. Actually, the hybrid shutdown is a variant of hibernate and sleep, a little of both and I think theoretically consumes much less power than hibernate or sleep but concerning laptops on battery I think it interesting that potential battery drain with the hybrid shutdown it is not really addressed anywhere or at least no where that I have seen.
    Thanks for your reply.
    Florida, USA
    Windows 8.1 Pro x64 with Media Center, Windows 10 Pro x64, Windows 7 x64 Ultimate SP1
    Shutting down with Fast Startup enabled does not use any battery power. It is a mode like hibernate (but not actually hibernate) where restart data is written to the hard drive. You will notice that Fast startup is not even available if hibernate is turned off.
    Hybrid sleep is another matter. It does consume power and it is really a mode intended for desktops.
    St. Augustine
    Quote Originally Posted by pbcopter View Post
    That was my impression.
    Windows 8 x64
    Fast Startup (...) is a mode like hibernate where restart data is written to the hard drive.
    And in order to keep that data alive guess what's needed. Power. Which is why it drains power, altough it's a lot less than when in desktop mode.
    Florida, USA
    No, during shutdown it writes data to the hard drive then all power is removed.
    Windows 8 x64
    Copter, it's quite clear to me you have no idea what you're talking about.
    There's an easy way to prove you wrong: put your computer (note that I say computer, not a laptop) to sleep or Hybrid Shutdown. When it appears to be off, remove your power cabble to simulate power loss for a few seconds then put it back and press the power button to attempt to wake it up/turn it on. First, you'll see your HDD led is on and not twinkling. You'll only get black screen with nothing on it. Then press the reset button and you'll get a pre-OS screen asking you to delete saved data from the disk. When you press Enter you'll get a normal startup.
    St. Augustine
    I believe that is what happens as well and that writing to the HDD is what is happening in the seconds during the hybrid shutdown process before the lights go out. But I have yet to find hybrid shutdown = zero power consumption when on battery documented in any technical material.
    Windows 8 x64
    I don't trust any documentation but my experience. So far I found out not everything is what it looks or sounds like on paper.
Page 1 of 2 12 LastLast
Heres the story... customer got bad viruses.. did clean up and removal of the infections and I noticed the laptop wasn't shutting down. (I cant confirm that this wasn't an issue before. I didn't notice it but doesn't mean it wasn't there) when you go to shut down the screen goes off but power on...
How to set automatic shutdown and power on in Performance & Maintenance
Hello good ppl of this forum! I'm looking for a way to automatically shutdown PC at midnight and turn it back on at 16h during work days (while I'm at work). Is there a way to do that in the built-in scheduler or is there an app for that? Weekends are fine as they are now, I'm looking only...
before u say anything , please read this part , since the title thingy doesnt allow me to write all of it , so here goes , will reverse OCing decrease power consumption in idle stage ? my PC is online 24/7 and since im pretty lazy , i dont really want to OC my GPU every time i get to play games ,...
I'm little apprehensive about recurrent force power shutdown I had to do during past one week in my lappy. First, I had to do it while the whole system got stuck up following Prime95 stability scan when I customised blend settings for CPU 100% load along with 92% memory usage. Next time it was when...
**EDIT: Included SF Debug zip** System Specs: CPU: i7-920 RAM: 12GB Corsair Dominator GPU: Geforce GTX 670 4GB OS: Windows 8.1 w/ lastest drivers from Windows Update Main Drive: Intel 510 120GB SSD
Hi, on Acer 3820TG (Win 8.1) I am trying to force system to use hybrid shutdown/fast startup function. I've already tried all steps from this topic: https://www.eightforums.com/tutorials/7806-fast-startup-force-use-all-users-windows-8-a.html but no success - system performs full shutdown. The...
Win8 Hybrid Shutdown/Fast Startup vs IRST? in Performance & Maintenance
I'm in search of the "fast boot" holy grail on: - Gigabyte H77M-UD3H motherboard - i3-3225 processor - 12GB RAM - two SSDs: 120GB Intel 520 & 64GB Kingston SNV425S2 - a 1TB HDD - Windows 8 Pro x64 (I hope that's all the relevant factors!)
