Power Consumption With Hybrid Shutdown?
  1. #11
    St. Augustine
    OK, Here is my little experiment:
    With my LP plugged in and Fast Start-up/Hybrid Shutdown enabled I shut it down (Hybrid Shutdown). I disconnected the power/charger cable then pulled the battery for a while, reinstalled battery, reconnected power/charger cable and hit the power button. Laptop went to fast start-up without any prompts just like it does if it was never disconnected from a power source. This would tell me that the hybrid shutdown results in no power consumption. Even though my laptop was void of any power source it restarted immediately just as it does when left on a power source. I may have answered my initial question but I don't have any technical data to document it.
  2. #12
    United States
    Windows 8.1 Pro 64-bit
    I dumped hybrid power down some time back. For me it was causing too many crashes/bluescreens after reboot and sometimes corruption. Since I have relied on fastboot only, no more such problems. Seems to boot just as quickly. My experience, yours may differ.
  3. #13
    Florida, USA
    Windows 8.1 Pro x64 with Media Center, Windows 10 Pro x64, Windows 7 x64 Ultimate SP1
    Quote Originally Posted by rado84 View Post
    Copter, it's quite clear to me you have no idea what you're talking about.
    There's an easy way to prove you wrong: put your computer (note that I say computer, not a laptop) to sleep or Hybrid Shutdown. When it appears to be off, remove your power cabble to simulate power loss for a few seconds then put it back and press the power button to attempt to wake it up/turn it on. First, you'll see your HDD led is on and not twinkling. You'll only get black screen with nothing on it. Then press the reset button and you'll get a pre-OS screen asking you to delete saved data from the disk. When you press Enter you'll get a normal startup.
    You can believe what you want but I stand by what I have said and I know what I am talking about thank you.
  4. #14
    St. Augustine
    Quote Originally Posted by popeye View Post
    Fast Start (Fast Boot) shuts down the computer in a hybrid fashion, that's why it starts faster than from a full shutdown. It's not hibernate and it's not sleep but a little bit of both. With Fast Start enabled you get the hybrid (variant) shutdown whether you want it or not.
    From Microsoft: https://msdn.microsoft.com/en-us/lib...(v=vs.85).aspx
    "To prepare for a fast startup, Windows performs a hybrid shutdown sequence that combines elements of a full shutdown sequence and a prepare-for-hibernation sequence."
    From all that I have read as well as my little experiment I think there is more reason than not to believe that with Fast Start enabled there is zero power consumption of a laptop on battery after shutdown. But sleep is a totally different matter.
    I am marking this thread as solved but additional comments are welcome.
  5. #15
    United States
    I really meant "hibernate" where I said "hybrid" but it all is a bit of smoke and mirrors IMO. If the OS is optimized for a fast start up I'm not sure any of these settings are that much better than a cold start.
  6. #16
    Florida, USA
    This tutorial contains a good explanation of Fast Startup.
    Fast Startup - Turn On or Off in Windows 8
  7. #17
    St. Augustine
    I tend to agree with you there. On my PC's, especially my desktop there is not a whole lot of difference between the Fast Start and Cold Start. I have never timed it but it just doesn't seem that much different, possibly a matter of seconds. Big Deal
  8. #18
    Fast starting = SSD
Page 2 of 2 FirstFirst 12
Heres the story... customer got bad viruses.. did clean up and removal of the infections and I noticed the laptop wasn't shutting down. (I cant confirm that this wasn't an issue before. I didn't notice it but doesn't mean it wasn't there) when you go to shut down the screen goes off but power on...
How to set automatic shutdown and power on in Performance & Maintenance
Hello good ppl of this forum! I'm looking for a way to automatically shutdown PC at midnight and turn it back on at 16h during work days (while I'm at work). Is there a way to do that in the built-in scheduler or is there an app for that? Weekends are fine as they are now, I'm looking only...
before u say anything , please read this part , since the title thingy doesnt allow me to write all of it , so here goes , will reverse OCing decrease power consumption in idle stage ? my PC is online 24/7 and since im pretty lazy , i dont really want to OC my GPU every time i get to play games ,...
I'm little apprehensive about recurrent force power shutdown I had to do during past one week in my lappy. First, I had to do it while the whole system got stuck up following Prime95 stability scan when I customised blend settings for CPU 100% load along with 92% memory usage. Next time it was when...
**EDIT: Included SF Debug zip** System Specs: CPU: i7-920 RAM: 12GB Corsair Dominator GPU: Geforce GTX 670 4GB OS: Windows 8.1 w/ lastest drivers from Windows Update Main Drive: Intel 510 120GB SSD
Hi, on Acer 3820TG (Win 8.1) I am trying to force system to use hybrid shutdown/fast startup function. I've already tried all steps from this topic: https://www.eightforums.com/tutorials/7806-fast-startup-force-use-all-users-windows-8-a.html but no success - system performs full shutdown. The...
Win8 Hybrid Shutdown/Fast Startup vs IRST? in Performance & Maintenance
I'm in search of the "fast boot" holy grail on: - Gigabyte H77M-UD3H motherboard - i3-3225 processor - 12GB RAM - two SSDs: 120GB Intel 520 & 64GB Kingston SNV425S2 - a 1TB HDD - Windows 8 Pro x64 (I hope that's all the relevant factors!)
