'Computer Memory Low' Problem
    Hi All.
    I have Windows 8 and keep getting a 'low memory' problem. I am dreadful on computers so haven't a clue what to do! It is an Acer Aspire laptop which I have had about 18 months and apparently has '8 GB DDR3 Memory'.
    I have attached all the screenshots which i can think of that may help anyone to diagnose why i am getting this low memory problem. If anyone could offer any advice that would be amazing!
    The problem here has nothing to do with a shortage of RAM but the high commit charge. This is currently 28.2 from a maximum of 31.8 GB. Under normal circumstances 31.8 GB is more than plenty. Typically the symptoms of a memory leak would be a high commit charge. To see the cause you need to select the "Details" tab and add the "commit size" column and show a screenshot sorted by that. There is no guarantee that will reveal the problem but it is a good start.
    Quote Originally Posted by LMiller7 View Post
    Thanks for your help. Below is a screenshot of what i think you are asking for (Apologies if not!).
    Austin TX metro area
    Lmiller7, I'd like to learn more about high commit charge! Is there a short document I can read about this? I'll be following along, listening in.
    The "Commit size" column is not shown by default but must be manually added. Right click on any column header and select "Select columns" from the menu and add the "Commit size" column. Resize columns so everything is visible.
    Edit: The commit charge is a rather difficult concept to understand and many articles get it wrong. You really need an understanding of how a modern memory manager works and that isn't simple.
    Ah okay, i've added it now.
    I noticed the top one is McAfee but i don't even use McAfee - it came with the laptop but i downloaded AVG to use.
    I think you have to uninstall McAfee using Revo Uninstaller or McAfee's own uninstall tool -- else, it still runs & uses resources.
    The McAfee commit might be high but it is less than 2% of the total. The problem is something else and rather beyond my experience.
    "Low Memory" is also used as a general warning when there is memory allocation problem and doesn't mean literary not enough. Are there just some particular program/s that gives you that warning ?
    Not really, the only sort of program i use is i play football manager, but ive had this message when ive not been playing it (such as when i was taking thr screenshots).
    Only thing i can think of is when i got the message this time i had 9 or 10 different tabs open on chrome. But the computer is generally really slow recently even when ive only got 1 or 2 tabs open, i'm desperate to sort out the problem!
Page 1 of 2 12 LastLast
Hi i have done a fresh install a couple weeks ago and have just been enduring this constant crash but it generally occurs after pc has gone to standby/sleep overnight and i see it when i return to the PC in the morning. Let me know what other information you might be needing. Thanks Ben ...
575815758257583 I'm not sure whats wrong with my pc. I haven't downloaded anything recently and im not running anything big enough to cause my pc to act like this. Anyone know what the problem could be, and maybe a solution?
I have the Acer Aspire AXC 603G UW13 and looking for a compatible CHEAP memory upgrade from 4GB to 8GB (maximum supported) And cheap is like less than 25$ I saw someone on a site doing a review saying they got a memory upgrade for only 20$ but they didn't list the site or from where the bought the...
Hi people! I have a laptop Dell 15r. Yesterday I decided to use the Recovery Media DVD Dell gave me and install Windows 8 from the beginning, after formatting, to have the pc as clean as possible. Of course, after installing W8, I installed W8.1 (always Pro version). I installed all the drivers...
Low Memory Problem in Performance & Maintenance
Hi, So the problem is i was playing CounterStrike And this popped up:39242 Any help please
Memory Management problem in Drivers & Hardware
Hello, I would be grateful if someone can tell how to resolve this problem. OS: Microsoft Windows 8 Pro CPU: AMD Phenom(tm) II X4 965 Processor, 3400 Mhz (RAM): 16,0 Gt Graphics card: GeForce GTS 450 SSD: Intel SSDSA2M080G2GC Motherboard: 770-C45
After my new build froze up during boot up into Windows 8, I tried to run Windows 8's built-in Windows Memory Diagnostic, extended setting, but it got stuck at 21% of 1st pass (10% overall) after running it overnight (at least 12 hours). I had 4x4GB memory modules, and re-ran this test with only...
