Help! laptop stuck at 28% charging
    windows 8 single language
    laptop wont boot until the charger is plug in what should i do?
    Canada
    If it only boots with the AC adapter plugged it chances are that the battery needs to be changed.
    i dont think so man. the battery indicator says its still at "Good" condition this happens when i remove the battery pack is it stil safe to use it? Ive tried removing the battery pack hold down the power button for 30 seconds then plug the charger many times any other solution or diagnostics?
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    I find your last post very confusing. So it won't boot with just the battery plugged in? Does the battery reach 100 % fully charged state? How old is this battery/laptop? It is safe to remove the battery and just run on the power pack.
    Laptop wont boot until the charger is plugged in and it its stuck at 28% charging and when you pull the charger out the laptop goes off too.
    You need to replace the battery with a new one.
    seriously man? any other troubleshooting tips? i am currently using my laptop now there's no other option sir?
    Using it as in, its plugged into the power pack? Go through the facts, the battery won't fully charge and the laptop will not run on just battery power. The battery doesn't last forever you know. They degrade as you use them. That's why they are easy to remove and replace. How old is this laptop/battery?
    ive been usin these for 2 years. im just hoping man that there's any other fix. if it's doesent have then i just go buy another one then
    I don't know of any other fix.
Page 1 of 2 12 LastLast
Samsung Laptop Not Charging in Drivers & Hardware
I think the laptop is fully functional but it can't charge. It ran out of battery now. I think the power supply is working because there was a green light :D. Is it caused by a problem in its motherboard?
Stuck configuring updates on new laptop in Windows Updates & Activation
I just got my Lenovo Ideapad Y500 back from Lenovo today after it needed its hard drive and motherboard replaced. I turned it on, set it up, and spent a couple hours downloading and installing things, as well as transferring files and uninstalling all the freeware that came with it. I accidentally...
Laptop Is Stuck? in Windows Updates & Activation
I need help, it's been like this for a day or so and I really need my laptop. Idk how long this would take... 43473
So I put my laptop into safe mode and then restarted. When it came on it was stuck on the pink screen. The only buttons displayed are the ease of access button in the lower left corner and the power button (with shutdown & restart options). It will not display the login screen or anything. I am...
Hello, I got a new laptop about 3 weeks ago or so and just today I noticed that it was charging but stuck at 95% I took the charger out let it drain down to 58% then put it back in again only to see that it's doing the exact same thing but now stuck on 58% I'm scared to drain the battery...
Hello, I bought a new laptop with Windows 8, and I was told at the shop to charge it at least 6 hours before the first boot. Is it really necessary? And if yes, why? Thanks :D
Laptop stuck in restart loop? in General Support
I don't know why but it has randomly started doing this in this order- 1. I turn it on, it does the normal start up screen of "Toshiba" and the loading animation underneath. 2. After a long time of waiting it takes me to a black screen. It stays that way for about 5 minutes, sometimes it does not...
