Dual monitor problem 8.0 vs 8.1
    windows 7 & 8
    Okay I have a little problem with Windows 8.1 Pro
    here is the scenario
    • 1 Windows 8.0 Pro tablet
    • 1 Windows 8.1 Pro laptop
    • both machines have a 50+ inch HD TV attached
    • each TV is set as the main display, with the tablet and laptop screens set as secondaries
    • each are running off the Intel on-board videos (that is all they have obviously)
    they both function great
    HERE IS THE RUB
    when I turn my HDTV off on the Windows 8 tablet,
    the TV just turns off and nothing happens, everything is still running on it (Which is good)
    BUT
    when I turn my HDTV off on the Windows 8.1 laptop,
    the laptop display then becomes my main display and every thing is transferred to it. (Which is not good)
    So how do I stop the 8.1 laptop display from becoming the main display when the TV is powered down?
    NOTE:
    the difference between the laptop/tablet display(s) is
    the tablet is 1920 x 1080 resolution
    and
    the laptop is 1366 x 768 resolution
    both TVS are 1920 x 1080
    Windows 3.1 > Windows 10
    Your Main Computer display screen should be the main screen - and the TV the second display..
    Usually you drag ( media player screen) over to second display which would be TV...
    but I am at a lose of understanding this (and every thing is transferred to it. (Which is not good))
    because Everything is actually running from within the laptop main screen, as the laptop is the source of the TV input
    windows 7 & 8
    Quote Originally Posted by KYHI View Post
    I use my tablet and laptop as my clocks (Alarm Clock HD) metro app. So I want that to always be displayed.
    I use my big screens for reading the paper, email, gaming, we use media center with cable card for TV, so they are the main displays,
    As I said Windows 8.0 works perfect, it is only the Windows 8.1 that does not.
    Side Note:
    Windows 8.1 also, does not function properly with my A/C WiFi
    not that, that matters any
    Thanks for the response
I have my two monitors in extend mode under Windows 8.1.1. I also have the 14.9 AMD CATS. Here's my tiny problem. If I have a window on the right side that has a tooltip it extends ever so slightly onto my second monitor. Sometimes it a border shadow, other times I can see the actual right...
Dual monitor in Performance & Maintenance
I don't know either this is the right place to ask or not. I just having my 2nd monitor. I just want to ask it is possible for me to play game and browsing the internet at the same time? The 2 monitors hooked up to the same graphic card. both of them is 23". So it is possible to play a full screen...
I recently purchased another monitor so I can run dual-monitors on my newly upgraded-to Windows 8 desktop. I set the monitor up last night, and I haven't had any major issues so far... One issue that I've run into, though, is the secondary monitor (regardless whether it's the monitor I owned first...
HP Dual Monitor Issue in Graphic Cards
I just upgraded to Windows 8 on my HP Pavillion dv6815nr. I am not having any luck connecting it to a second monitor. I followed the basic steps under "screen resolution", but my computer is not identifying the second monitor. I read that you need to go to Nvidia's control panel to connect to a...
Dual monitor problem in Graphic Cards
GPU: mobile intel express 4 series chipset family Displays: 2x Dell 1907FP connected to a dell dock. Other peeps here all got the same setup but there's one person who has a problem where in windows 8 it won't use the other monitor till he removes the driver and re-detects it again and...
Dual Monitor Lag in Performance & Maintenance
As of upgrading from Win 7 Pro, to the preview release of win 8, my second monitor while playing a game in full screen will lag for example. Using ventrilo there will be a 2-3 second delay for the green light to show up, where as the sound is instant. If i have a video running while i'm in...
I am having some problems with the Windows 8 start screen on my dual monitor setup. I have 2 monitors (d'oh) the monitor in the center of the desk is my main monitor. The monitor to the left is my secondary monitor. I have My desktop showing on my main monitor (the right or center monitor) I...
